5w-30 or 10w-40 or ? - Team Camaro Tech
Thread Tools Display Modes
Old Aug 11th, 11, 10:47 AM
Melrose RS Melrose RS is online now
Tom
Default 5w-30 or 10w-40 or ?
Did a cam change back in winter and haven't really driven the car but around town a few times. Now I'm preparing for a road trip this weekend and want to change the oil to get that crane cam lube out of there.
I've got Cam-sheild additive but was wondering whether I should use 10w-40 or 5w-30 oil. The engine was rebuilt with new rings and bearings about 10 years(5,000) miles ago.
Thanks.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
Old Aug 11th, 11, 11:15 AM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
Default Re: 5w-30 or 10w-40 or ?
Tom
I've been using 15-40 Rotella, with cam additive, since the last rebuild.
Mark
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
http://www.camaros.net/forums/member.php?u=3230
Old Aug 11th, 11, 11:21 AM
Vintage 68's Avatar
John
Red face Re: 5w-30 or 10w-40 or ?
Sorry, don't remember you build ...
Is this engine built to spec.s that require/use 5w oils?
If it's a non-LS SBC, I would recommend the 10w base for some street units, 15~20w for others - dependant more on spec.s and conditions it is operated in ...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Aug 11th, 11, 12:13 PM
Everett#2390's Avatar
<Jake-68's rule
All I have ever used whether on the track or street, 10W30.
Old Aug 11th, 11, 12:35 PM
Nashville Beth's Avatar
Nashville Beth Nashville Beth is offline
Banned
Bethanne
X2 on what Everett says, plus I would use full synthetic with the cam shield additive.
Old Aug 11th, 11, 02:04 PM
Tom
John, born-with 67 L30 with stock rebuilt bottom end. FT Crane 272 cam. Will be using Cam-Shield additive. I suspect it may have run 10w-40 or 30(?)most of it's life (when my grandfather was in the driver's seat)
I should also add that I do start and drive it in the winter, even in 20-30 degree F weather on occasion when the (roads are clear).
Old Aug 11th, 11, 02:13 PM
Vintage 68's Avatar
John
Wink Re: 5w-30 or 10w-40 or ?
Out here it's 'warmer' ...
15~20w-## is normally close to a year round choice for older street vehicles.
Run 15w-40 Delo in my boats and trucks ...
0~5w-20/30 Mobil-1 in the newest ones.
1968 Convertible
Some trucks
Old Aug 11th, 11, 08:56 PM
BillK BillK is offline
Tom,
Rather than use an additive, I would get an oil that has the additive package built into it. Valvoline VR1, Brad Penn, Gibbs racing etc now all offer an oil that is designed for flat tappet cam engines. As far as weight goes, it really depends on what the clearances were when the engine was built. 10W30 should be safe for almost anything.
Interesting article: http://www.enginebuildermag.com/Arti..._slippery.aspx
Just my opinion,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
Enginerepairshop.com
Old Aug 11th, 11, 09:10 PM
Steiner Steiner is online now
Steiner
Take a look at the Rotella T6 synthetic 5W-40. You get the good cold flow of the 5W with the increased shear stability of the 40W versus a 30W. Plus last time I checked one of their oil analysis over on bitog it still had about 1200ppm zinc in it.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Aug 12th, 11, 01:23 AM
97Z4C 97Z4C is offline
darrell
another one for 10w 30 and additive or valvoline
  #11
Old Aug 12th, 11, 02:30 AM
Steiner
Just an FYI if it matters....Valvoline dropped the zinc level in the 30 weight versions of VR-1 to 1100ppm last year.
'69 Camaro
500hp/538lbft
www.cmengines.com
  #12
Old Aug 12th, 11, 07:19 AM
mbrekke's Avatar
Mark
Not trying to hi-jack your thread Tom, but since we Americans usually go with 'more is better' is there such a thing as too much of a good thing when it comes to zinc in oil?
Mark
  #13
Old Aug 12th, 11, 07:34 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Amsoil has always had elevated ZDDP levela but now they went further and designed a special oil for those who use flat tappets:
Zrod oils
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
  #14
Old Aug 12th, 11, 09:50 AM
Tom
Mark
No problem Mark! I think I read somewhere that too much zinc can cause galling
  #15
Old Aug 12th, 11, 01:42 PM
DT DT is offline
Donny
Summit Racing's brand 10W40 for me. 1800 ppm of zinc NO additive needed.
1969 X66 396 LeMans Blue, M20, 373 ...
1969 Convertible (just arrived)
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 5w-30 or 10w-40 or ?
Location
Location
First Name
Human Verification
