Removing broken fender bolt - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Aug 16th, 11, 09:32 PM
Acidburn Acidburn is offline
Tom
Default Removing broken fender bolt
When removing my front fenders, the lower bolt on the passenger side snapped at the head. What are y'all's recommendation for removing this bolt with the least amount of invasive surgery possible? Thanks!
1967 Camaro - LM7, T56, TVS
1996 Impala SS - DD
Old Aug 16th, 11, 09:36 PM
Speedjester Speedjester is offline
Hector
Default Re: Removing broken fender bolt
Weld a nut on to it.. Then while it's still hot back it out...
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Old Aug 16th, 11, 09:48 PM
Geezer Geezer is offline
X2, The heat will loosen up the rust via expansion and will usually come out easy. If I need to heat a bolt a little longer and the area around it I use a jewelers torch.
Ron
The Junk Yard Dog
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Old Aug 16th, 11, 10:52 PM
BPOS BPOS is online now
Al
I've welded a nut on a time or two and it usually works pretty well. Sometimes though it's on a part you don't want to get that hot, and the left-hand drill method works well also. http://www.madelectrical.com/worksho...en-bolts.shtml
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Aug 16th, 11, 11:14 PM
69z28freak's Avatar
69z28freak 69z28freak is offline
Mike
Every Camaro fender I have taken off did the same thing. Heat is the way to go. Torch seems to do the trick on all rusted bolts.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
http://www.camaros.net/forums/showth...ght=69+grandma
BC Camaro Club
http://www.bccamaroclub.com/#!builds/c8ky
The Rod & Custom Shop
http://www.therodandcustomshop.com/
Old Aug 17th, 11, 07:39 AM
vambercidw vambercidw is offline
Travis
Same thing happened to me trying to remove bolt from door hinge. Did same thing, welded nut on and then removed. Worked like a champ.
Old Aug 17th, 11, 08:29 AM
cuz13 cuz13 is offline
Steve
If welding nut doesn't work u can cut off and drill out retap afterwards. This would be last resort. I only suggest this from experience when I welded the nut on the bolt twisted and snapped. Good luck
Old Aug 17th, 11, 08:57 AM
Vintage 68's Avatar
John
Thumbs up Re: Removing broken fender bolt
Agreed that welding a nut to the remaining stud usually works
I also try to get a candle into the thread base area while it's still hot to meld some wax into it - the wax will 'wick' into the threads and help lubricate it during removal.
I've had some success by spraying penetrating oil on them after welding also, if I can't access area to do the candle trick ...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Aug 17th, 11, 10:07 AM
6781camaro's Avatar
6781camaro 6781camaro is offline
Todd
Been in this situation too... and crayons will work well too if you don't have spare candles. (plus you can choose the color of your choice)
'69 Frost Green V8 Coupe-Building now!
'68 Sequoia Green V8 Coupe--Building now!(too)
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
http://www.camaros.net/forums/showthread.php?t=146455
Old Aug 17th, 11, 10:47 AM
stouchton stouchton is offline
Scott
Soak threads with Kroil or PB Blaster overnight. If you have enough threads, jam 2 nuts together and back out -or- vise grips - or - screw extractor.
If no go, drill .050" under size of threads and it will loosen. Best if you have a left hand bit.
  #11
dhutton dhutton is offline
Weld a nut onto it and the apply a good shot of Kroil. That stuff is amazing. I got mine on ebay.
Don
  #12
Old Aug 17th, 11, 11:13 AM
6781camaro's Avatar
Todd
God bless PB Blaster! That spray is amazing and has gotten me out of plenty of rusty jams. You have a few dependable options here to chose from. Let us know how it worked out.
Locking two thin nuts together is a great idea too. Clean, no welding or heat needed, but I would still spray it up (soak it) with PB Blaster and let it sit for a few hours. Then go back to it. Tap it a few times lightly with a hammer when spraying it. It sometimes helps distribute the PB Blaster into the threads.
My build thread:
  #13
Old Aug 17th, 11, 04:40 PM
Google PB Blaster vs Kroil....
Don (former PB Blaster user)
  #14
Old Aug 17th, 11, 08:10 PM
Z10396 Z10396 is online now
Yep, this is what I did. It just kept snapping off when I welded a nut to it. Drilled it out and tapped the hole.
  #15
Old Aug 17th, 11, 08:34 PM
Steptoe Steptoe is offline
Steps
This is an old thread and there is another on the same sort of subject.
I have used the weld method for decades, never failed, not just into steel and cars, machinery cast and even Al and brass....and pipe fittings in valley covers.
If u break the weld that means u havint the penitration required for a good weld
When u weld a new bolt on...
taper the end of the bolt 1st...sort of the same way of welding heavy plate V ing out.
With a good punch, dimple the end of the broken stud...simply giving a few good wacks helps loosen
Turn the heat way up and feed right down..chances are the settings on the welder are for panel steel or something lighter.
One of the best 'tricks' told me years ago is spend the week before dismantling an old car or anyhting like that, use some good penitration oil and each night u come home from work go around and spray all bolts studs screws etc.
Good luck
"Luck is directly related to the effort put in"
Mark Twain
"Work hard at being lazy"
My Grandfather and Dad.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Removing broken fender bolt
Location
Location
First Name
Human Verification
