ignition wiring - Team Camaro Tech
Old Aug 29th, 11, 05:18 PM
Hunter68 Hunter68 is offline
Hunter
Default ignition wiring
does anyone have a diagram of how the ignition is supposed to be wired?
Old Aug 29th, 11, 06:17 PM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: ignition wiring
From the ign sw, 12 GA pink wire to firewall connector.
Engine side of firewall connector is a cloth covered orange with white strip resistive wire to coil + terminal.
Coil - terminal to dist point set.
Return path of circuit is through dist plate through a braided wire strap, to dist body to block to battery.
Also, coil+ terminal has a yellow wire from the R terminal on starter solenoid.
The above description is for a '68 & '69 OE wiring.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Aug 30th, 11, 01:49 PM
Hunter
that doesnt sound like all the wiring like theres 2 brown wires and a big purple one
Old Aug 30th, 11, 02:26 PM
BPOS BPOS is offline
Al
Can you post some pictures? "Please" and "Thank you" will likely attract more responses.
Purple probably goes to "S" terminal on starter. The tach feed wire is brown in the factory loom, so one or the other might be for that, and would go to neg side of coil.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Tags
diagram, ignition, wiring
