I am not getting gas to my QJet - Team Camaro Tech
Old Sep 3rd, 11, 06:21 PM
Weave67RS Weave67RS is offline
Tech Team
Question I am not getting gas to my QJet
Due to a surgery, I last drove my 1967 Camaro in February. I keep it on a Battery Tender Plus under a car cover. So I pulled off the cover yesterday and tried to start her up. She turns over fine but will not start. I have a 1/2 tank of gas. I pumped the accelerator still nothing. I pulled off the air cleaner and manually pushed the throttle...no gas in carb or the smell of gas. So I removed the line into the 4bbl-QJet and had my son crank it over. Gas came out of the line. I replaced the fuel filter. Sill nothing. I used a couple of shots of starting fluid in the QJet and she fired up but stopped right away. I tried this a few more time and the same result. So I am turning to Team Camaro members for help. Thanks in advance.
Old Sep 3rd, 11, 07:34 PM
go2fast go2fast is offline
Jim
Default Re: I am not getting gas to my QJet
Float could be stuck. Time to take the top off the Q and see if there's any fuel in the bowl.
Old Sep 3rd, 11, 08:17 PM
Vintage Musclecar Vintage Musclecar is offline
Needle & Seat is stuck shut, happens fairly often on carbs that don't get driven for extended periods.
Try GENTLY rapping on the front of the carb at the top of the fuel inlet with a plastic hammer or the back of a heavy screwdriver, sometimes that will be enough to un-stick them. Don't flail on it, just rap on it a few times. If that doesn't free it up, the top of the carb needs to come off.
Carburetor Rebuild & Restoration
www.vintagemusclecarparts.com
Old Sep 4th, 11, 05:15 PM
69-Pace's Avatar
69-Pace 69-Pace is online now
x2 x2 float or needle issue. It may be time for a rebuild kit.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old Sep 4th, 11, 05:41 PM
Everett#2390's Avatar
<Jake 68's Rule
X2 on the stuck needle to its seat. If rapping with a rubber hammer doesn't help, might remove fuel line and inject a short burp of compressed air.
Then fill the bowl through the vent tube.
You may end up having to pull the carb and clean it of old gasoline. Carb cleaner through every orifice, and new gaskets.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Sep 4th, 11, 08:37 PM
Tech Team
Smile Re: I am not getting gas to my QJet
As always the members are a wealth of knowledge. Vintage Musclecar THANKS. I gently used the side of of a plastic screwdriver and tapped the front of the carb Saturday night. Sunday afternoon I pumped her a few times and she fired right up. So I drove her about a half an hour plus. Labor day I will be out their again. Thanks Team Camaro.
Old Sep 5th, 11, 01:22 AM
97Z4C 97Z4C is offline
darrell
you still might have issues --if so pull it and recondition it-if its low on power and idle quality, the power valve is stuck also
Old Sep 5th, 11, 11:58 AM
Glad to be of service.
