| Team Camaro Tech Current Topic: smoke | ||
| Troubleshooting Diagnosing problems done here. |
rebuilt engine aftermarket heads slightly used edlebrock intake. smokes when i mosh it on the street but not at the same rpm in the driveway. how bad is it?
What colour smoke?Blue ,white ,or black?
------------------ DVC-98.Racing 470 cubes of fogger injected thunder in a 71 z. racing@mbox303.swipnet.se |
it looks white but i can only see it in the mirror it may have a blue tint
Is there any fluid on the underside of the car? Where? What color is it?
Could be an oil pan gasket or trans leak... |
no fluid under the car. if it was a leak wouldn't it smoke all of the time?
Is car auto or stick?
Smokes under load only.Correct? Colour is white-as in blown headgasket? Might be your vaccum modulator. It controls the upshifts of the autobox. If you follow a rubber hose(small) ,at the base of the carb,it connects to a pipe-leading down the pass side of the car. There it will be connected to a hose again that goes to a funky looking canister. If you disconnect the line at the base of the car-temporarily-,and the smoke vanishes,you have a busted diaphram in that modulator. A new modulator is VERY cheap and VERY easy to install. What gives the smoke in that case,is the motor burning auto fluid.Very characteristic white smoke. ------------------ DVC-98.Racing 470 cubes of fogger injected thunder in a 71 z. racing@mbox303.swipnet.se |
