Body weight ? - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Nov 3rd, 11, 04:33 PM
gn69z28 gn69z28 is offline
Greg
Default Body weight ?
I know this has been answered before but I dont remember.How much does a 69 Camaro body shell without frontend sheet metal weigh. Just the bare empty shell to put on a body cart. I need an idea to figure out best way to pick one up and place on cart. Thanks.
Old Nov 3rd, 11, 04:41 PM
Vintage 68's Avatar
John
Red face Re: Body weight ?
Did you try a "search"
Really - http://www.camaros.net/forums/showth...y+shell+weight
And 'best' way to pick one up is an overhead lift or 4 friends and
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Nov 3rd, 11, 06:34 PM
tjgimp tjgimp is offline
Tim
Default Re: Body weight ?
Greg,
I put it on the cart myself. Check out my build thread post #106. I slid the cart in from the side. It was pretty easy. Just use jack stands, some lumber and a floor jack. My car is a mess so I braced it beforehand. Good luck.
Tim
My 1968 convertible build:
http://www.camaros.net/forums/showthread.php?t=175855
Old Nov 3rd, 11, 06:57 PM
6781camaro's Avatar
6781camaro 6781camaro is offline
Todd
Originally Posted by tjgimp View Post
Greg,
I put it on the cart myself. ... It was pretty easy. Just use jack stands, some lumber and a floor jack. ....
Same here... Raise up the shell as high as you need with either jackstands or piles of heavy lumber and then slide the cart underneath into position to lock it on the locator pins.
'69 Frost Green V8 Coupe-Building now!
'68 Sequoia Green V8 Coupe--Building now!(too)
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
http://www.camaros.net/forums/showthread.php?t=146455
Old Nov 3rd, 11, 07:01 PM
6781camaro's Avatar
Todd
In the pic attached, you can see my new "steel" body cart waiting to be pushed underneath the car in the background. I used 4"x4"x7' posts to suspend the shell on jackstands. I made sure to raise it high enough so the old "wooden" body cart can slide out to the side, and so the new "steel" body cart slide in from the back of the car.
Go slowly and it will happen. I thought seeing this pic may help.
Click image for larger version
Name:	wooden body cart is ready to roll out.jpg
My build thread:
Old Nov 3rd, 11, 09:01 PM
69Project 69Project is offline
Lee
I used two eng hoists, not because it was too heavy but because the body was too akward for just one unless I had a body lifting device like the link shows below.
This company sells this. http://www.accessiblesystems.com/bl.php
I thought about it but didn't pursue it since I had was able to manage the body with the two engine hoists I had laying around and I could use the $300 for something else, like paying for my floor pan. It's a neat idea though.
Old Nov 7th, 11, 02:58 PM
69-er 69-er is offline
Larry
About 600 pounds. 350 - 400 at the rear.
Current Project:
66 Chevy C10 Resto-Mod
Next In Line: 69 Z/28 Resto-Mod
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Body weight ?
Location
Location
First Name
Human Verification
