Mig welding with silicon bronze wire? - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Nov 6th, 11, 05:33 PM
Bangcamaro Bangcamaro is offline
Tech Team
Chris
Default Mig welding with silicon bronze wire?
Ok forgive me if this has been posted before but i am curious about mig welding panel seams with the silicon bronze mig wire. I just now found out they make it for the mig. and i know people are already doing it with a tig. Has anybody tried this? I am looking for a solid way to seal up the seams as i replace panels to avoid any "cracking" of the paint or filler. I saw seams sealed this way on a build recently and it is beautiful and seems to be the perfect way to finish off a panel. i did find out that if you do use this wire in a tig to use a slightly oversized tip because the wire can bind up. Other than that it should work right?
Old Nov 6th, 11, 07:19 PM
allanjs allanjs is offline
Al
Default Re: Mig welding with silicon bronze wire?
Chris, You also need to use 100% argon gas. I haven't personally tried it but
it looks intriguing. Do a Google search and you will find some good info.
http://www.google.com/search?hl=en&b...50l350l3-1l1l0
Al
my 67' build thread: http://www.camaros.net/forums/showthread.php?t=190185
Old Nov 6th, 11, 09:26 PM
Tech Team
Chris
Exactly. I read that too. Im just wondering if anybody has tried it before i gamble money and time on a spool. I hate the idea of welding on new panels and not having them sealed up very well. Just filling them with filler just doesnt seem good enough. I have thought of just leading them but you can also get cracks with lead. I can't afford a tig which is how i have seen them do it. I guess the main issue will be if it sticks or not.
Old Nov 6th, 11, 09:28 PM
Tech Team
Chris
If nobody has tried it im going to buy a spool and try it on a couple pieces of scrap. I may or may not be onto something but worth a try. I saw a roll online that was only 32 bucks.
Old Nov 6th, 11, 09:32 PM
Tech Team
Chris
http://youtu.be/THdWfsLiSrk Here it is! it can be done.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Mig welding with silicon bronze wire?
Location
Location
First Name
Human Verification
