Harbor Freight floor jack. Any good?? - Team Camaro Tech
Tools & Shops Shop Rat HQ
Old Nov 13th, 11, 10:33 AM
DT DT is offline
Donny
Default Harbor Freight floor jack. Any good??
Looking at a HF 2.5 Ton low profile floor jack. The name on it is Pittsburgh Automotive. Anyone have any experiences with this brand???
396 X66 LeMans Blue, M20, 373 ...
Old Nov 13th, 11, 10:47 AM
77thor's Avatar
77thor 77thor is offline
Fred
Default Re: Harbor Freight floor jack. Any good??
Is that their $59.95 racing jack?? I've never heard of the brand.
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Nov 13th, 11, 10:49 AM
rockin rollin rockin rollin is offline
i brought one from them afew yrs. back and have had real gooood luck with it. its a central hys. brand from??? orange in color-2-1/4 ton
Old Nov 13th, 11, 11:02 AM
3forme 3forme is offline
Vince
Costco has a real nice jack for 99
1959 Pontiac Catalina 389 tri power
1967 Camaro Convertible ordered from Spain docs
1969 Camaro cpe with POP
1969 Camaro cpe 57K orig mile w/window sticker &POP
1999 Acura 3.5RL
1999 Southwind 32V
2000 Tundra V8
2008 Tundra bigger V8
DT DT is offline
Donny
Thanks for the replies. Its grey in color and was 99.00 plus 10.00 shipping. I couldn't believe shipping was only 10.00. The thing is 78 lbs or so.
Old Nov 13th, 11, 11:03 AM
DT DT is offline
Donny
Thats really the one I want. Arcan 35xl or something. Not sure my local Costco has it.
Old Nov 13th, 11, 03:29 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
Yeah and its not on the Costco website any longer.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old Nov 13th, 11, 04:42 PM
cuz13 cuz13 is offline
Steve
I bought the costco one last year, great jack low profile quick pump.
Old Nov 13th, 11, 07:52 PM
Steiner Steiner is offline
Steiner
Ditto on the Costco jack. Friggin' love that thing. The place that services them is in the next town over from me. They're still in stock at my local store.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Nov 14th, 11, 07:19 AM
rj68RS rj68RS is offline
Russ
A friend of mine has this jack and I've used it a couple times. The only thing I noticed is it will settle after a bit so definitely use jack stands if you are climbing under the car, removing a wheel, etc.
On jack stands, I have 4ea from Harbor Freight, their 12 ton ones that go to 24" tall. Got them half off so could not beat them.
Russ (RJ)
The Garlic Capital, Gilroy,CA
1968 RS convertible that is not quite stock
Pics: my drop top driver
Old Nov 14th, 11, 08:45 AM
Vintage 68's Avatar
John
Thumbs up Re: Harbor Freight floor jack. Any good??
Originally Posted by rj68RS View Post
... The only thing I noticed is it will settle after a bit so definitely use jack stands if you are climbing under the car, removing a wheel, etc.
DEFINITELY use Jack Stands
No matter who's jack you buy or use!!!
Even my best old Walker can 'settle' just a little after sitting for a few hours - no sure I've ever had/seen a jack that couldn't/wouldn't eventually settle just a little, or even drop all the way to ground if they had some internal wear ...
I had a trans jack do it on me years ago when I ran for some parts and left the trans 'temporarily' just held in the air so I didn't have to disconnect all the wiring and connections ... well, the parts run took longer than expected, I stopped for lunch, the tides changed and the trans-jack settled enough to 'hang' the trans from the kick-down cable and tip it back so (nearly) all the fluid drained out the tailshaft onto my floor and the back-up wiring got ripped out ... lesson learned
Now - back to question ... I have three (3) HFT jacks now; 3-ton, 2.5 ton and a 2 ton alum. (on semi-perm. loan to SIL ...)
The first two are 5~7 years old and used weekly, the last one was bought a couple years ago for an emergency repair over at kids house, and just left there for them. All three have given excellent service so far, not one of them has leaked a drop ...
I have a couple older Walkers at my shop and while the HFT's aren't near the quality (and 'heft') of the Walkers, they raise the vehicles (and a porch overhang the other day ) I need them to and work just fine for the work they were intended for
I've never had one give me any trouble so far.
BUT - I always block and install Jack-stands and then lower the vehicle on to them BEFORE I even think of crawling under
btw - maintaining a jack is very important for long life and use!
Always clean the hydraulic ram of debris before lowering if you've had it under areas you were scraping dirt/junk off at and it's gotten on the ram (another reason to block/jackstand and remove the jack before work).
And make sure to check fluid levels as well as wipe the ram clean and apply a little oil, I use "Tr-Flow", to the cylinder ram while it's extended before storing again.
Make all the pivots and pump contact points have a light coat of oil/grease to prevent wear and problems during operation.
I've also changed the oil in my Walkers every 5~10 years depending on use - it's not hard to do and I think it has helped the oldest one (probably @40 years old now ) last as well as it has.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Nov 14th, 11, 05:34 PM
BPOS BPOS is offline
Al
I have a 2.5 ton HF jack and it's been fine for several years. Anymore, it's not where the jack is made, it's where do you want to buy your Chinese jack. My jack from HF is no better or worse than the Chinese jack I bought at NAPA. If HF has the best deal, go for it.
Surprised to learn that Pittsburgh and Chicago are now in China, though. When did they move?
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Nov 14th, 11, 10:38 PM
alanrw alanrw is offline
Alan
Harbor Freight is a pretty big company. Hard to imagine they would knowingly sell a crappy jack which could result in a lot of lawsuits no? I would think that something like a jack would have to pass some sort of testing.
alan
Old Nov 15th, 11, 05:59 AM
gene68ss gene68ss is offline
Team Member
Gene
I have been useing the Harbor Freight aluminum jack for a couple of years. It has performed great for me, I like it and on sale is was very well priced.
gene68ss
Old Nov 15th, 11, 09:37 AM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
I have 2 of the blue aluminum jacks in a couple of my work trucks....I have had each for a couple or three years in outdoor conditions always. They both work great and I really like how light they are.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
