Choosing wiring harness. - Team Camaro Tech
Old Nov 24th, 11, 06:22 AM
vics67rs vics67rs is offline
Tech Team
Corey
Question Choosing wiring harness.
Hello there, my name is Corey and I'd like to rewire my 67 camaro converted into a rs. This was my dad's car that was left to me and I'm trying to make it perfect. I want to rewire because I've had a few issues with wiring breaking and bad connections in plenty of connectors. I've read some other forums about this but I still cannot decided on which harness to get. Painless? M&H? Classic Industries?...etc. This camaro has a sbc 400 with th350 transmission, hideaway head lights, a/c, console gauges, console shifter. Was originally equiped with 6cyl 2 speed, factory a/c, column shifter, gauges in intrument cluster. I'd like to get some what of a plug and play wiring harness and not really have to cut, splice, and crimp lots. I want to replace every wire on the car but cannot seem to figure out witch harnesses to buy. Most of the ones I look at don't come with a/c heater wiring, or not for console gauges, or no hideaway sections. Please help, just want to make it right.
Old Nov 24th, 11, 06:49 AM
77thor's Avatar
77thor 77thor is offline
Fred
Default Re: Choosing wiring harness.
Contact American Auto Wire(AAW), they are the best out there, they will have what you need.
http://www.americanautowire.com/
They have an online catalog.
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Nov 24th, 11, 07:01 AM
69-Pace's Avatar
69-Pace 69-Pace is offline
x2 on the American Autowire harnesses. They have the Factory Fit line that is an EXACT duplicate of the factory harness including original style fuse panel and glass fuses, or you can "modernize" to the new prong style fuse panel.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old Nov 24th, 11, 09:37 AM
reelknots reelknots is online now
Steve
I just purchased and installed an engine wiring harness from AAW and it was spot on and looked original.
69 SS, 350/300 h.p., M-20, 12 bolt, matching numbers.
"http://i376.photobucket.com/albums/o...s/IMG_2107.jpg"
Old Nov 25th, 11, 06:03 AM
layne02 layne02 is offline
jeff morrison
American Auto Wire in mine. I don't know if they are all like this from AAW , but mine was an " updated kit", not an original factory . So there was no wiring for external voltage regulator, so I had to get a 1 wire alt. . I know it came with wiring for gauges but nothing for A/C. It didnt have power window wiring also. So, you may have to improvise on a couple of things depending what your car already has in it. But it was well worth the money and I will definitely buy from them on the next one. Great product.
Old Nov 25th, 11, 06:24 AM
67 455 Bird ragtop 67 455 Bird ragtop is offline
Team Member
Mark
M&H Fabrications. Spot on like original.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
http://community.webshots.com/album/222472397caZdha
Old Nov 25th, 11, 07:07 AM
69-Pace's Avatar
AAW has several lines, but the Factory Fit product line is original OEM. The update product lines are flexible and modular and you order what you need including charging circuit. It is easier to call them and order custom update harnesses over the phone.
Old Nov 25th, 11, 07:40 AM
Mkelcy Mkelcy is offline
Mike
+1. They'll also customize their harnesses in various ways.
Mike - Building a '68 Camaro with lots of stuff done to it.
http://img9.imageshack.us/img9/6301/img0372vm.jpg
Old Nov 25th, 11, 12:03 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Originally Posted by 67 455 bird ragtop View Post
m&h fabrications. Spot on like original.
x2
Plug and Play.... or Plug and Drive if you prefer.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Nov 26th, 11, 07:50 AM
BigBlock1969RS's Avatar
BigBlock1969RS BigBlock1969RS is offline
Ed
AAW here as well very happy with it, went with their Classic Update line. Very good support via email and phone.
