Troubleshooting Diagnosing problems done here.
Old Mar 17th, 99, 12:18 PM
Uni Uni is offline
Default
I have a '73 rs that turns over but will not catch. It is starting to backfire through the muffler and somettimes the carb. I've changed the wires and points and condenser. I have the points set around .17 thousandths.
What could be my problem
Old Mar 17th, 99, 07:56 PM
68RS 68RS is offline
Tech Team
Default
It sounds like a couple of things could be wrong. First, check the easy things like the coil, cap, rotor, firing order (18436572 for those of you who haven't embedded these #'s in your heads already). Next, I would check to see if the timing is off (timing chain slipped). Last, you may want to pull a valve cover off to see if you have a valvetrain problem like a couple of bad lifters, broken rockers or a flat cam.
Old Mar 18th, 99, 04:26 AM
Dino Dino is offline
Default
Check to see if you have blown a power valve..
