Do you know what this hole is for on firewall? - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Dec 21st, 11, 08:52 AM
tonyvol tonyvol is offline
Default Do you know what this hole is for on firewall?
Hey guys, I'm trying to install a Vintage Air in my 67 Camaro and wanted to do something alittle different from what the instructions mention. I want to run the wires through this hole(the one with yellow tape), but I'm not sure what it was used for originally. I looked at the original heater box and the studs don't go through this hole. The hole in the picture(marked with yellow tape) is where I want to running the wires. Does anyone know what this hole was used for? Maybe to fasten the firewall pad?
Thanks,
Old Dec 21st, 11, 10:14 AM
cuz13 cuz13 is offline
Steve
Default Re: Do you know what this hole is for on firewall?
that would be my guess although the heater box does that as well
Old Dec 21st, 11, 10:23 AM
zlek131 zlek131 is offline
Matt
Not sure but I have the same hole in my 68. I ran the a 4 gauge wire to the trunk via that hole. Make sure you use a rubber grommet!
Matt
68 RS
72 RS/SS
Go for a 68 ride
Old Dec 21st, 11, 10:28 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Firewall pad grommet, I used that hole for my amp power line
Old Dec 22nd, 11, 05:02 AM
Thanks guys for the excellent help. Exactly what I needed to know.
