Rally Wheel ID markings? - Team Camaro Tech
Wheels & Tires What fits what?
Thread Tools Display Modes
Old Dec 21st, 11, 08:09 PM
islanddean's Avatar
islanddean islanddean is offline
Dean
Default Rally Wheel ID markings?
My 15x7 Cragar's are on the way and I'd like to sell my rally wheels but need some help in properly identifying them. I can see a stamp on the inside of the rim that appears to read "k14" but cant be sure. Could someone tell me what this stamp may indicate? Thanks.
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
Old Dec 21st, 11, 08:52 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
Default Re: Rally Wheel ID markings?
From CRG:
http://www.camaros.org/suspen.shtml#Wheels
Code is on the rim by the valve stem hole as well as some of the information on the face or the wheel.
Format is:
K1y m (Valve Stem Hole) dd aa
where:
K = Kelsey-Hayes
1 = Romulus, MI wheel plant
y = calendar year
m = month
dd = day
aa = application code
K19 8 (hole) 4 YH = a 69 Z28 wheel built by
Kelsey-Hayes for Chevrolet on 8/4/69.
K14 = 1974 rim. What are the month and day and application code?
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear.
Finally back on the road after being stranded in the garage for over 20 years. Follow her progress back to the road http://69pace.blogspot.com
Old Dec 23rd, 11, 06:46 AM
69-Pace's Avatar
Dean I posted a reply to your posting over at CRG but in case you get here first:
FW = 15X7 B-4 1/4 71-up most any GM
Old Dec 23rd, 11, 04:50 PM
islanddean's Avatar
Dean
I found a magnifying glass and was able to read the stamp:
k17 6 24 FW.
Any ideas? I cant seem to find the k17 part along with the fw part.
MLK
Old Dec 23rd, 11, 06:09 PM
srode srode is offline
Steve
Manufactured 6/24/1967 is the first part, not sure what FW stands for though, it's the application / models used on.
69 Pace Car and 69 Hard top
Old Dec 23rd, 11, 07:02 PM
69-Pace's Avatar
The FW series didn't start until 1971 so the wheel in question is a 1977.
FW 15X7 B-4 1/4 71-up most any GM
Yeah red and green how could I not.
From Team Chevelle:
When looking at original GM wheels, they will be stamped around the edges of the valve stem. This is good information to have, because it gives you the size / backspace / production date of the wheel. Below is a list of the available GM information;
XA 14X5 B-3 1/2 67 Chevy II with drum brakes
DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with disc brakes
XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 B-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 B-4 3/8 70 Chevelle Station Wagon
XG 14X6 B-3 7/8 68-69 Camaro with disc brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 B-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 B-4 3/8 69 Chevelle SS Wheel
AO 14X7 B-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 B-4 1/16 67-68 Camaro Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Riveted instead of welded together
YS 15X6 B-3 1/2 68-70 El Camino
AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 Camaro Z28 5 spoke wheel
AZ 15X8 B-4 69-82 Corvette
Here are a few extra notes:
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
* All the hubcaps interchange with each other.
Old Dec 24th, 11, 11:01 AM
1967 Plum 1967 Plum is offline
Dee
Wow, great informational post. I'll have to go check my rallys now.
1967 RS/SS350 Camaro (mostly stock)
1969 RS/SS Camaro (being improved!)
Old Dec 25th, 11, 08:49 AM
islanddean's Avatar
Dean
that was an AWESOME post. Thank you for your help and reply. I was hoping I had some rare wheel worth millions. Oh well....maybe next time.
MLK
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Wheels & Tires      Current Topic: Rally Wheel ID markings?
Location
Location
First Name
Human Verification
