Easiest way to adjust driver door on a 68 Camaro - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Jan 3rd, 12, 05:15 PM
68Maro 68Maro is offline
Tech Team
Junior
Default Easiest way to adjust driver door on a 68 Camaro
I have a small problem, my driver door hangs a little ,what is the easiest way to adjust my driver door on my 68 camaro.
Old Jan 3rd, 12, 06:19 PM
scblucam's Avatar
scblucam scblucam is offline
Scott
Default Re: Easiest way to adjust driver door on a 68 camaro
First see if you need to rebuild or replace the hinges. If you grab the door and lift is there a lot of play?
68 302 M20 - 85 IROC Z
The older I get the faster I was.
Old Jan 3rd, 12, 06:31 PM
Tech Team
Junior
both hinges are brand new, i just need a easy way to adjust the door.
Old Jan 3rd, 12, 07:28 PM
Tech Team
Junior
If anynone has a good and fast way of adjusting the door plz let me know.
Old Jan 3rd, 12, 09:57 PM
clill clill is online now
Charley
There is a great tool that body shops use that fits in the door latch and the stud the latch latches onto. It is a pry bar and you tweek the door up. Problem solved in bout 30 seconds
Old Jan 4th, 12, 07:35 AM
Charley
Here's one that works the same way but uses a breaker bar as the handle.
http://www.northerntool.com/shop/too...7349_200337349
Old Jan 4th, 12, 09:22 AM
Everett#2390's Avatar
<Jake-68's rule
You could also use a 4X4 and floor jack.
Old Jan 4th, 12, 09:39 AM
Vintage 68's Avatar
John
Thumbs up Re: Easiest way to adjust driver door on a 68 camaro
I've done a ton Ev's way
But I bought the tool Charlie describes a few years ago from Summit - http://www.summitracing.com/parts/SNG-82350/
I works really well!
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jan 4th, 12, 10:13 AM
Sauron67MM Sauron67MM is offline
Scott
You could, but it's better to do it using the door shell with the tool. Standard tool in a collision shop and works better on some doors than others. If you use a jack and wood, cut a channel in the wood block so the door hem sits in it, similar to an aluminum Jackpal. Among the alignment tools available, here is another one. A design can be made quickly for a one time use instead of purchasing one: http://www.autobodytoolmart.com/cham...r-p-11508.aspx
The jamb hinge bolts are not impossible to access, and they make a door hinge wrench. Or one can easily be made after heating to bend it. I'd just loosen the hinge bolts to adjust the door.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Easiest way to adjust driver door on a 68 Camaro
Location
Location
First Name
Human Verification
