| Team Camaro Tech Current Topic: Engine Codes and Component Question | ||
| Tag Team De-coding tags and numbers. |
If I were looking for a date correct 2bbl intake for the engine that is supposedly the original that I got with my car what numbers would I be looking for based on the pictures below. Or are these not he numbers I should be looking at, rather the Vin#?
________________________________ 1969 Camaro BB Coupe / 468ci / th400 / 12bolt / Black with Red Int. http://s923.photobucket.com/user/dby...20Coupe?sort=3 |
| Sponsored Links | ||
Advertisement | ||
HF engine application code is 350ci/250HP L65 used with a Powerglide, which was a 2 barrrel engine.
There should be a date code on the block back on the bellhousing flange behind where the distributor would mount. That date would help you match up the block to a correct dated intake. December 18 is the engine assembly date. So intake would probably be dated 1-2 weeks before that. Maybe more. The 3932386 casting number block was used early in the 1969 model year from around August of 68 to January of 69. So you should look for an early December 68 dated intake in my opinion. I think the intake casting number should be 3927183.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street. Looking for 68 Camaro with body number NOR 181016 CRG - www.camaros.org Last edited by bcm66; Jan 6th, 12 at 08:25 PM. |
Thank you for the help Bryon.
You are welcome. I am glad I could help.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street. Looking for 68 Camaro with body number NOR 181016 CRG - www.camaros.org |
| Sponsored Links | |
Advertisement | |
