Official Sponsor of Team Camaro |
| Team Camaro Tech Current Topic: 73 LT Electronic ignition to HEI Conversion | ||
| Second Generation 1970-1981 |
Hey guys, great site, great forum, thanks for setting this up.
I have a 73LT that has been converted to electronic ignition (by previous owner) 350 V8-Auto 10.5-1 compression, Edelbrock top end kit, 670 holley carb, Taylor HEI Distributor I now would like to convert it to HEI. This is a fresh build-nut and bolt 7 year restoration, new engine, never been started. I'll try to describe to the best of my ability, I am not a mechanic- but like to pretend ----bear with me-------thanksI have a resistor wire (which is clearly stamped "resistor wire do not cut") that has been joined in a solderless connector with two other wires. One is black which comes from a cyindrical resistor type object mounted to the fire wall---this has a brown wire bolted to the other side of it(assuming this is the tach). The other is a yellow wire which runs to the starter. What do I do?? New part is the: HEI distributor from Taylor (max 6500 rpm) Do I need to replace the resistor wire with a 10 to 12 guage wire or can I use the existing wire and splice it into the accel 2 pin connector adapter. Do I eliminate the cylindrical object with the brown wire attached(assuming this is the tach) and run directly to the HEI coil area marked tach? Can I eliminate the yellow wire running to the starter? What do I do???? Thanks Dom |
| Sponsored Links | |
Advertisement | |
