| Team Camaro Tech Current Topic: Where to buy outlet fitting for new pwr steering pump??? | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
I found ONE on ebay that I believe will work but it's $40..
Any ideas of where I could find one? All of the pumps I've seen for sale that are the early saginaw style have the female outlet port in the pump. We need the male version as the stock hose is female on the pressure hose (end that goes into the power steering pump). Anyone know where I could find just the fitting for my new pump? Thank you, Donnie
68 Camaro - 580 HP 412 CI, TH350, full manual, 3500 stall, 3.73 eaton posi, 17 inch Intro's. Jet black. Lowered. |
| Sponsored Links | ||
Advertisement | ||
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
NAPA
Weatherhead 1586 inverted flare to flare It's actually the late model pumps that are female port. Not many of the old cores left around....
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
Ty! I'll check out that fitting @ Napa..ALL of the pumps I've seen for sale (at least in the photo in the listings) have the female fitting on the pump itself for the high pressure side. I LOST my whole power steering pump somehow so having to buy a new one. Thanks again, Donnie
Is this what you need??
http://www.heartbeatcitycamaro.com/s...ting-67-68-69/
396 X66 LeMans Blue, M20, 373 ... |
You bet. If they don't have it they should be able to get it in a day. $10-$15 or so.
That's a bummer, because I'm pretty sure you could have unscrewed the fitting from your old pump and used it on the new one.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler |
. That's why I'm so bummed, trying to avoid this cheap iroc steering swap turning expensive. ![]() I'll definitely check out napa..that heartbeat one on the link is pretty pricey and it appears to be for an AN fitting on the hose end??
Wanted to edit this as I put the wrong part number earlier. It should be Weatherhead 1563.
Sorry for the confusion.
OR you can use the hose from a 74 nova it uses the female pump fitting and has the same shape as the camaro.
TTFN Mat
SSCARGO |
| Sponsored Links | |
Advertisement | |
