Fuel line too close to header? - Team Camaro Tech
Thread Tools Display Modes
Old Feb 18th, 12, 03:43 PM
hazman1969 hazman1969 is offline
Tech Team
DK
Default Fuel line too close to header?
1969 Camaro, small block to big block conversion. I just ran a new fuel line from tank to engine (didn't have line when I got car). Can you tell from pics if the fuel line is too close to the headers? My concern is that it will heat the fuel in the line. Thanks for any feedback
Click image for larger version
Old Feb 18th, 12, 03:58 PM
camarodude67 camarodude67 is offline
Default Re: Fuel line too close to header?
Not to bad maybe some type of heat shield cover for the gas line.
Jeff G.
Old Feb 18th, 12, 05:35 PM
MW67RS MW67RS is offline
Matt
That looks pretty close to the header. Maybe a 1/4" or so. I would definitely wrap it in a good heat blanket material or do something to shield it from the heat from the headers. The good thing is it only looks close to the front primary tube so it shouldn't get as hot as if it was further back.
Mine was pretty tight also and I used one of the plug wire insulators over the fuel line. I don't have the car done yet so I cannot say well it works.
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
Old Feb 18th, 12, 09:36 PM
Fred Mertz Fred Mertz is offline
Dave
I just installed a new line front to back. I thought the front section up the inside of the frame rail was too close to my headers. I cut the line under the car just before it crosses over the frame rail into the engine compartment and made a new one from 3/8 x .035 alum. tubing. I ran the line on top of the subframe instead of along the side by the idler arm.
Dave
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:42.
Old Feb 19th, 12, 08:05 AM
Tech Team
DK
Thanks for all of the great replies...i think im just gonna go with some type if heat shield/sock that slips ovee the line...
Old Feb 19th, 12, 08:45 AM
68zz502fi 68zz502fi is offline
Maurice
id' take a look at mcmaster carr for heat/fire resistant sleeves. they have many to choose from. you should be able to find something there that will work for your particular situation.
BE different....ACT normal.
No one is completely useless..They can always be used as a bad example
Old Feb 19th, 12, 12:44 PM
srode srode is offline
Steve
I thought mine was a bit too close also, so I ran it over the top of the frame rail instead of around the idler arm. Mine wasn't as close as yours by the engine mount / frame area so I left it there. I think fuel moving through it is going to keep it cool and with ceramic coated headers they don't get that hot, they keep the heat inside much better than uncoated.
69 Pace Car and 69 Hard top
Old Feb 19th, 12, 01:28 PM
Tom P's Avatar
Tom P Tom P is offline
Tom
I did something similiar except adapted the hard line to black braided hose to route it on top of the frame rail over to the Fuel Pump.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Old Feb 20th, 12, 02:11 PM
mnm99's Avatar
mnm99 mnm99 is offline
Marc
Wrap the fuel line with some heat sheild. Don't know if you can see it from the regulator.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
Old Feb 21st, 12, 08:04 AM
JAYARTER JAYARTER is offline
JAY
I ran new fuel lines on the outside of the frame and came under as close as I could to fuel pump...... see photobucket...KIMS NOVA and MIKES NOVA to see how I ran fuel and trans lines outside frame to hid them...Jay
http://photobucket.com/photobucketcomJayBj
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
  #11
Old Feb 21st, 12, 08:58 PM
gordr's Avatar
gordr gordr is online now
Gordon
Jay,
In my SS396 67 machine, my fuel line is about 1/8th of an inch from the header and my builder said wait til it becomes an issue before doing something about it. So, after 2 years of running in all kinds of hot 100 degree plus weather, nothing's ever happened. Yours is further away than mine so just leave it.
Gordon
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Fuel line too close to header?
Location
Location
First Name
Human Verification
