402 BBC Combos/desktop dyno - Team Camaro Tech
Thread Tools Display Modes
Old Feb 18th, 12, 06:01 PM
Bambinomontana Bambinomontana is offline
Default 402 BBC Combos/desktop dyno
I had a previous post asking for help putting my combination together and this is the final outcome (thus far). I'm looking for someone to do a desktop dyno to see what type of power this will yield. I also would like to hear of anyone with a similiar set up, to see if there is something I'm not thinking about or what little mods helped get the most out of their combination.
Thanks,
BAM
1967 Camaro
402 BBC (414ci)
60 over forged speed-pro pistons, 10.5 compression
H beam connecting rods 6.135
Forged 3.76 crank
Edelbrock aluminum head 110cc (2.19 intake and 1.88 exhaust)
lunati hydraulic roller 292/300 (241/249 @50), 625/625 lift or 231/239 at .050, .600/.600
Turbo 400, trans brake, 3000 stall
12 bolt with 4.10 gears
29.5 x10.5 MT's, CE traction bars and sub-frame connectors.
Old Feb 19th, 12, 02:04 AM
buenymayor buenymayor is offline
Default Re: 402 BBC Combos/desktop dyno
What intake, which Edelbrock head, what carb., LSA?
Experience...... It's what you get when you didn't get what you wanted.
Old Feb 19th, 12, 12:16 PM
Edlebrock RPM oval intake
Edelbrock 60449 Performer RPM Cylinder Head -110cc oval
Holley 850DP (jets 82/84, power valve 3.5/4.5; depends on the weather, don't know if you need that much info).
CAM 1:
Hyd.
Hyd.
2600-6200
60213
NA
292
300
241
249
.625
.625
110
CAM2:
Hyd.
Hyd.
2200-5800
60212
NA
282
290
231
239
.600
.600
110
Thanks a lot,
BAM
Old Feb 19th, 12, 03:17 PM
Arch Stanton's Avatar
Arch Stanton Arch Stanton is offline
John
I can get kinda close.
the .625 cam makes 573hp at 6000 and 551tq at 4500.
the .600 cam makes 555hp at 6000 and 553tq at 4500.
I told it to use "large tube headers with mufflers" and to use Edel 6045 heads.
- John
Misfit tortured soul. Lone wolf.
'67 V8 Camaro - 12637, 797-Z, M-M, 2M, 3K, 5Y
Old Feb 19th, 12, 03:29 PM
Thanks, that's the range I was expecting, I figured 550hp. I have 2 1/4 headers, that's pretty large...;0)
Thanks again,
Ivan
Old Feb 19th, 12, 03:31 PM
WOW, just noticed that the .600 cam made more torque, interesting.
Old Feb 19th, 12, 06:26 PM
Lonnie P's Avatar
Lonnie P Lonnie P is offline
Lonnie
Seems odd that 2 different cams with a 10deg duration difference show peak power at 6K.
Old Feb 20th, 12, 11:25 AM
71454Chevelle 71454Chevelle is offline
Tech Team
IMO, both of those HP figures seems abit generous.
Darren
71 Chevelle 496
CFM Ported Stage 5 Brodix RaceRites 310cc
10.5cr
Ultradyne Solid Roller 256/264 .660/.660 108lsa
CFM Ported Victor Jr/Pro Systems 1000HP
T-56 Magnum
12 Bolt TrueTrac 4.56 gear
30x12.5 ET Street Radial
525++ rwhp
Old Feb 20th, 12, 12:13 PM
Hopefully someone can run the figures over again and confirm or deny the results.
Bam
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 402 BBC Combos/desktop dyno
Location
Location
First Name
Human Verification
