Leaking Holley carb. - Team Camaro Tech
Thread Tools Display Modes
Old Feb 19th, 12, 02:04 PM
jjgrizz73 jjgrizz73 is offline
Jeff
Default Leaking Holley carb.
Hey everyone, I decided to finally try and figure out this holley carb problem again. I bought the carb used/rebuilt and had problems with leaking venturis. I bought another rebuild kit thinking it was the power valve or something else, it wasnt. I cleaned the whole thing out and it still leaked and wouldn't let the engine idle. Anyone have ideas? I'm thinking it could be a warped base plate because it does seemed warped but not sure if it would cause this issue. It is not the floats I played with them for hours and they are set perfectly. Fuel pressure was also set. I have an edelbrock on there now, but I'd like to get this holley working properly.
1967 Camaro RS :
461 LS6 BBC
Super Cased Muncie M22Z
12 bolt Posi
http://www.nepastreetscene.com/forum/forum.php
Old Feb 19th, 12, 08:10 PM
Steptoe Steptoe is offline
Steps
Default Re: Leaking Holley carb.
OK think about it, the carb gets bolted to the base plate...then the warped base plate gets bolted to the valley cover...and gets bent...what happens then to the stuff already bolted to the base plate.
Holley, well most carb manufactures make a big deal about toquing down carbs correctly, and not just because of possible manifold vaccuum leaks.
Old Feb 19th, 12, 09:08 PM
frankk frankk is offline
You say the venturies are leaking. Is there raw fuel leaking out of the venturies? If so you have float problems possibly stuck, seat not sealing or hole in float.
wot
Old Feb 19th, 12, 09:21 PM
camaro_fever68's Avatar
camaro_fever68 camaro_fever68 is offline
Ray P.
Pull the little brass screws on side of the bowls and see if the fuel level is correct. You want the level set right to the bottom of the hole.
Another thing to check is the gasket between the main body and baseplate. Most carb kits come with 3 different base gaskets for 600, 650-800, and 850 CFM carbs. If the right gasket was not used it will cause the boosters to leak fuel and kill the engine.
Never seen a warped baseplate cause fuel to pour out, mostly vacuum leaks.
Ray
Old Feb 19th, 12, 09:29 PM
Straight-line-69 Straight-line-69 is offline
If you see fuel leaking with the engine running, look for somthing around the fuel bowl; accelerator pumps are a likely source.
Old Feb 20th, 12, 05:48 AM
Jeff
Yes there is raw fuel leaking out of them. I changed the needle valves and set the floats correctly but I guess there can be a problem with them sealing correctly. I never took the main body off the base plate, I can do that. What would I be able to do to eliminate the possible accelerator pump issue?
1967 Camaro RS :
461 LS6 BBC
12 bolt Posi
Old Feb 20th, 12, 12:42 PM
Remove the carb from the engine and replace the little pump diaphram. Easy,..four little screws. Not sure which Holley you have but this is probably what you need:
http://www.summitracing.com/parts/HLY-135-5/
Old Feb 20th, 12, 01:26 PM
Steps
If it "seems" warped without actually checking, and it is, the chances are it is going to be damn warped...and if it has been warped that far the question arises what else in this 2nd had carb has had the crapper screwed out of it, twisted warped over torqued, bits of wire jambed down in places should never have been, drilled out etc etc.
And yes we have seen 1 carb over the yrs that was so warped it leacked, wouldnt seal or even jet up right.
2nd hand carbs that MAY need a rebuild always causes problems and end up costing more money more headackes than simily dialing a the corect carb out of the box.
Just go thru the threads here alone with 2nd hand carbs and issues.
Old Feb 20th, 12, 04:46 PM
Jeff
I checked the base to see if it was warped its not visible by just looking at it.
1967 Camaro RS :
461 LS6 BBC
12 bolt Posi
Old Feb 20th, 12, 07:59 PM
Steps
cant check by just looking....use a known straight edge, check both sides of the base plate and the manifold.
Take extra care looking at the mounting cnrs are not 'bent'
  #11
Old Feb 20th, 12, 08:16 PM
Warped baseplate? As stated above, that would cause a vacuum leak but not a fuel leak. Again, if she's dripping with engine running, look around the fuel bowls.
  #12
Old Feb 20th, 12, 08:58 PM
rszmjt rszmjt is offline
Mike
Jeff - What is the list number of the carb, and does it have centre pivit floats or side pivit floats. Does it have the Brass floats or the nitrophyl (black) or the duracon (white plastic). Also is the fuel coming out the front boosters or the rear secondaries?. How much fuel pressure do you have? How big is the engine, and how much camshaft? Need more info to try to figure this out.
Take the carb off and turn it over, are the throttle blades about 1/4 to half way up the idle transfer slots? If they are a bunch higher it is probably pulling the fuel out of the boosters, which is normal with too open a throttle blade.
Post all this info Please.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
  #13
Old Feb 21st, 12, 04:31 AM
Everett#2390's Avatar
<Jake-68's rule
If fuel is leaking/dribbling from the venturis while idling on level ground, I would think the fuel level is set alittle too high.
  #14
Old Feb 21st, 12, 01:30 PM
Jeff
Here are some pictures...The base plate is NOT warped, I checked it today again. Im not sure of the list because the choke was milled off. Center pivot floats(brass). I believe the fuel was coming out of the secondaries, its been a long time though. Fuel pressure was at 5.5-6psi. Motor is a 461 with these cam specs:
  • Advertised Duration (Int/Exh): 268/276
  • Duration @ .050 (Int/Exh): 227/233
  • Gross Valve Lift (Int/Exh): .542/.554
1967 Camaro RS :
461 LS6 BBC
12 bolt Posi
  #15
Old Feb 21st, 12, 05:29 PM
Steps
Good.. then it is either
crap in the inlet bowl valves..they/it is not closing off...or mis matched damages seats.
Float level(s) not set correct...drop the fuel levels down, fire up, pull the sight scews, shake the car side to side.. the fuel should just slop out the hole.
And u will know when the secon butterflies are nor adjusted correct...the idle and mixture screws will not be in the factory 1 1/2 turns out... adjust secondaries on the car with engine running.... a bent rivet with 1 end flatened to fit up under the edge and use as a screw driver....no not have the butterflies sitting on the bores...fully closed..caused binding and damage.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Leaking Holley carb.
Location
Location
First Name
Human Verification
