Installing parking brake - Team Camaro Tech
Thread Tools Display Modes
Old Feb 21st, 12, 04:41 PM
mjlynch71 mjlynch71 is offline
Jerod
Default Installing parking brake
I am putting in a new parking brake assembly in, in my 1969 Camaro. The cables are already inplace, but am putting in a new assembley under the dash. How hard is it to remove the cable at the end of the pedal. The old one is currently hooked up, but unbolted from the firewall. The current one is nasty looking and the return spring does not work either. Thanks, Jerod
Old Feb 21st, 12, 04:52 PM
Steptoe Steptoe is offline
Steps
Default Re: Installing parking brake
There are several older posts over the last 12 months describing , how to in details ..espec the clip to release the cable.
Old Feb 21st, 12, 08:23 PM
Jerod
Still could not find out excatly how to get the cable off of the parking brake assembley, so I can put the cable on the new parking brake assembley. Thanks, Jerod
Old Feb 21st, 12, 08:51 PM
gordr's Avatar
gordr gordr is offline
Gordon
Yep, it's real tricky....I lost my retaining clip when it flew off when I let the brake pop back up when I pulled the release handle. The cable disconnected right there. So, look for that little retaining clip as in the below pic and take it off...your cable will come off easy after that. Be sure you've loosened the park cable under the car first so there's lots of slack. Make sure you remember how that clip comes off, take a pic of it before taking it off. Not easy to get back on if forgetting how it goes back. Also, the park brake light switch paddle goes on in a tough way...if you have one...
Gordon
Click image for larger version
Name:	park brake retain clip.jpg
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Installing parking brake
Location
Location
First Name
Human Verification
