Removing Rust Stains From Grill pieces and bezels - Team Camaro Tech
Body Shop Paint & Body Forum
Old Feb 25th, 12, 06:06 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Default Removing Rust Stains From Grill pieces and bezels
Hey guys,
I'm wondering what some of you have used to remove rust stains from the upper and lower grill mouldings? The area affected on mine is the thin line of exposed aluminum or whatever that material is. The pieces are for a standard grill on a '68.
I currently have them soaked with a rust remover for porcelain but so far no dice. I'd like to repaint them and reuse them as they are in very good condition other than a few rust stains.
Thanks for any replies.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Feb 25th, 12, 08:11 PM
Garfields Maro Garfields Maro is online now
Garth
Default Re: Removing Rust Stains From Grill pieces and bezels
Any kind of metal polish suitable for aluminum should work.
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Feb 26th, 12, 09:28 AM
Everett#2390's Avatar
<Jake 68's Rule
Alum wheel polish, Alcoa sells their own brand and works nice, T-shirts work nice for working the polish and buffing. Large enough also when the spot is black, move to a different place.
3M Finesse, Chrome polish, fine rubbing compound, and lastly, I find and bikers really like, Mr. Buffer, polishes anything incuding low carbon steel.
I used Mr Buffer to polish/remove sticker adhesive in the bottom of a stainless dog bowl and the bottom became a mirror.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Feb 26th, 12, 09:33 AM
Michael Gekko
Thanks for the replies. I used some emory cloth and it took out the stains completely.
Old Feb 26th, 12, 02:24 PM
Garth
...yeah, but did it scratch it ?? Was also gonna suggest fine steel w(0000)l, but......
Old Feb 26th, 12, 02:27 PM
Michael Gekko
Nah, it was just 3 places, each about the size of a half of a dime.
Old Feb 26th, 12, 06:40 PM
Steptoe Steptoe is online now
Steps
Rust stains and mild corrosion on chrome use a sheet of kitchen Aluminium fiol crushed up loosely with..in orgder of avaibilty/prefernce Coke a cola, thinner, water
Havnt tried on Alumium surfaces but certainly not as abrasive as some of the suggestions.
Maybe worth a try.???
Old Feb 26th, 12, 07:11 PM
Michael Gekko
Steps,
I thought about using a source of phosphoric acid but figured I could control the emory cloth better...the stains were very slight.
Ona another note, kids over here have made small bombs with plastic bottles of Coke (and maybe other sodas) with aluminum foil stuck inside. I think there may be one other ingredient, maybe not I can't remember. Anyway, kids would put the AL foil in the drink bottle and leave it on someone's lawn or garden...when someone picked up the drink to throw it away the recipe would mix up and become active, creating a small explosion. Some people have lost hands and gotten burned badly.
Old Feb 26th, 12, 07:27 PM
keithl1967 keithl1967 is offline
Keith
Naval Jelly...
Keith
1967 Camaro
Bought it in 1994:
230, PG w/ 314K miles!
Today:
Motor "in progress": 406, 10:1, comp xr282HR, Dart Iron Eagle 200cc, Holley Contender dual plane, Holley 750 DP
Muncie M-20
GM 8.5, 3.73 posi
Old Feb 26th, 12, 08:57 PM
Steps
Steps,
I do have straight phosporic here and my chemistry tells me it should turn the stain black...which could cause even more issues, maybe??
I have tried the phosoproic an iron stains in our old enamal bath and didnt do anything except etch it a liitle in that spot....
I dont want to upgrade the bath to a modern one...modern ones are too wide, use to much water go cold too fast and designed by someone with a Phd and no bloody commonsense lol
Emery , even steel wool could leave sanding marks that in them selves could be a bigger mission to get out...therefore I would try the Aluminum foil ( called tin foil down under)
And if not a fine stainless polishing rouge stick rather than a cutting compund.
Old Feb 26th, 12, 10:21 PM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
Foil in the coke bottle:
http://video.google.com/videoplay?do...71256076875223
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
