Inconsistent idle?? - Team Camaro Tech
Thread Tools Display Modes
Old Feb 27th, 12, 06:05 PM
islanddean's Avatar
islanddean islanddean is offline
Dean
Default Inconsistent idle??
Here goes. New plugs, plug wires, new dizzy, coil, points and condenser. Just installed a new Edelbrock 1406 carb and new front engine wiring harness. Car started right up and runs like a scalped ape but I noticed an inconsistent idle.
When in gear and while in park the engine seems to idle great then I can hear the engine rev up just slightly for a few seconds then return to normal. This is constant. Dwell is at 27 and timing is 10 btdc. Any thoughts?
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
Old Feb 27th, 12, 06:40 PM
Steptoe Steptoe is offline
Steps
Default Re: inconsistent idle??
This is usually caused by too light springs in the cent....coming off at idle speed, adding a couple degrees of advance speeds up the engine, not enough fuel to maintain the higher rpms and drops back again
similar
The Vaccuum advance can is not all in at idle (manifold vaccuum)...and doing the same.
Or similar again, if on ported vaccuum and the butterflies, be it secondaries or primaries open to far or primarires open too far because the secondaries are to far closed, actuvating the VA can.
There are other issues that can also cause this, like inconsistant fuel or crap in the idle cirvuits of the carb.
Old Feb 27th, 12, 07:30 PM
1SLOW64's Avatar
1SLOW64 1SLOW64 is offline
jeff
get a holley
CURRENT PROJECT: 1969 X66 RALLY GREEN/BLACK COMFORT WEAVE, OWNER INSTALLED RS PACKAGE
1987 BUICK GRAND NATIONAL SOLD
2002 C5 COUPE ELECTRON BLUE SOLD
1964 CHEVY II 406 SOLD
Old Feb 27th, 12, 08:08 PM
islanddean's Avatar
Dean
I'm an Edelbrock man. The last good holly I used was for a boat anchor.
MLK
Old Feb 28th, 12, 12:29 PM
Steps
Of all the carbs, my preference is holley.
Any old secondand hand carb is a boat (small boat) anchor.
over 90% of carb issues here and in real life are people trying to save a few bucks, picking up 2nd hand carbs and trying to make them work...then spending evemn more money and time to do so.....often then dumping and picking up a new carb pres set up in ball park for their application.
By this time the have figured out how the carb actually works, that they are 3 carbs in one body and how to actually dial them in.
Holley is still most proberly the easiest to tune in, work on and reliable with good performance ..As to which is the best performance depends on the the person and knowledge , tools behind the actual tuning.
Old Feb 28th, 12, 05:08 PM
rj68RS rj68RS is offline
Russ
I always like to check the easy stuff first.
1. Check for vacuum leaks at the carb base to intake and intake to heads. Also the port to the distributor. There may be better ways nowadays but I always used a spray of carb cleaner and listened for a change in the idle.
2. If using a mechanical throttle linkage, check your motor mounts. Not uncommon for motor mounts to look good but have cracks/tears that allow the motor to move around enough to affect the throttle linkage. There are many threads on this.
If this doesn't help then deep dive and check the carb and distributor.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
Pics: my drop top driver
L30 327 L30 327 is offline
Eric
Originally Posted by 1slow64 View Post
get a holley
x2
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Inconsistent idle??
Location
Location
First Name
Human Verification
