69 front bumper installation - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Feb 29th, 12, 05:18 PM
RJBaileyrn's Avatar
RJBaileyrn RJBaileyrn is offline
RJ
Default 69 front bumper installation
Hi guys,
Putting my front bumper back on the 69 RS. Am a bit in the dark as to what all is needed. I have two brackets for each side, two of them go out by the bumper ends, and the other two are more inboard. Is there a center bracket on a 69? If so, how doew it attach, don't see the holes. Also are there rubber bumpers for the 69? I don't seem to have them, or do the front bumpers just bolt up solid to the brackets. Help and pics GREATlLY appreciated. I went through a bunch of threads, but never really found out everything.
Thanks guys,
RJ
69 RS coupe, 4.11 Richmond gears, Muncie 4-speed, Dart SHP 406, 11:1, 4340 H-beam rods and crank. SRP forged pistons, Milodon 7-qt pan, Dart single plane and 215cc Pro1 alum heads, Comp XR300HR cam and roller rockers, Howard hydraulic roller lifters, Hooker 1 3/4" Super Comps, Quick Fuel 750 carb
Old Feb 29th, 12, 05:45 PM
BPOS BPOS is online now
Al
Default Re: 69 front bumper installation
There is an endura (urethane?) optional bumper for a 69 - not sure if that's what you meant.
No center bracket - just the 4 you mentioned.
I start with the outers - the bolts are adjustable. Get them close but don't crank em tight (bracket to bumper) - just snug.
I put a floor jack with a 2x4 lengthwise under the flat part in the middle and carefully jack it up to where I want it. Tighten the two inners then the 2 outers. Probably other ways to do it - a helper is nice to keep from butchering the paint. Consider masking tape at likely rub points.
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Feb 29th, 12, 05:49 PM
RJBaileyrn's Avatar
RJ
Not an enduro.
NPD shows a 69 bumper to valence bracket, but I don't see any holes for that.
Also, once you put in the end brackets and bolt it tight, There doesn't seem to be alot of movement available. My bumper sits lower on the right end than on the left. Not sure where to proceed in making it level.
RJ
Old Feb 29th, 12, 05:55 PM
Al
The outer brackets have adjustment in the bolt that attaches the bumper to the bracket.. Big hole in the bracket. Just don't crank that bolt tight until you're ready. The inners as you know are two brackets that ultimately attach the bumper to the subframe, so a lot of adjustment there.
can you post a link to the NPD bracket? I've owned a 69 since I was about 17 and have never seen this 5th bracket that you speak of!
Old Mar 1st, 12, 07:01 AM
RJBaileyrn's Avatar
RJ
Al,
Unless I'm reading this wrong, page 151 of current NPD catalog shows:
1969
Bracket & cushion Center bumper to valence
C-7869-11B
$9.95
Also, do I need the rubber cushion for the outside bumper brackets?
RJ
Old Mar 1st, 12, 09:30 AM
Al
Well I looked it up and there it is. I have no idea what that is. Possibly a typo. My Rick's catalog shows that same bracket but lists it for a 68 with which I'm unfamiliar.
http://shop.autocraftinvestments.com...-117784-0.html
http://www.rickscamaros.com/camaro-f...hion-1968.html
Old Mar 1st, 12, 09:56 AM
RJBaileyrn's Avatar
RJ
I saw that too in the Rick's book this morning, must be a mistake.
Again, does your 69 have rubber bushings for the end clamps?
RJ
Old Mar 1st, 12, 10:05 AM
Al
RJ
Yes it does
Old Mar 1st, 12, 10:12 AM
Sauron67MM Sauron67MM is offline
Scott
Only 68's have a center bracket with a rubber bumper.
Old Mar 1st, 12, 01:50 PM
RJBaileyrn's Avatar
RJ
thanks
  #11
Old Mar 1st, 12, 02:00 PM
Al
No prob - post a picture of your car - sounds potent!
Oops - looked at your profile - beautiful car!
  #12
Old Mar 1st, 12, 05:20 PM
RJBaileyrn's Avatar
RJ
Thanks Al, Haven't gottem it out on the street much, still putting little things back together, should be running this weekend.
RJ
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: 69 front bumper installation
Location
Location
First Name
Human Verification
