| Team Camaro Tech Current Topic: roller rockers that fit under Z28 valve covers?? | ||
| Engine General Engine Discussion. |
I need a set of roller rockers for my 69 z.but I want a set that will fit with out removing the baffolds.
Thanks Rich
1969 Garnet Red Z/28-RS with Black stripes and Black Deluxe Int. I found my build sheet ![]() 2012 Shelby SVTPP GT500 race red with dash signed by Caroll Shelby ![]() RIP Mr Shelby |
| Sponsored Links | ||
Advertisement | ||
Full rollers will not work under stock valve covers...you may be able to pick up a set of roller tipped rockers, though.
Keith 1967 Camaro Bought it in 1994: 230, PG w/ 314K miles! Today: 383, Dart Iron Eagle heads, Eddy Vic Junior, Holley 750 DP--450HP+ Muncie M-20 GM 8.5, 3.73 posi |
When I bought my car,(350ci) it came with full roller rockers and Z-28 covers BUT there was a 3/4" alum spacer under the valve covers.
69 SS, 350/300 h.p., M-20, 12 bolt, matching numbers. "http://i376.photobucket.com/albums/o...s/IMG_2107.jpg" |
http://www.compperformancegroupstore...Code=SBCRocker
I have Harland sharps on my 1974 Z they work with drippers use thick gaskets to clear the poly locks you'll be fine.
1974 Z28 Second owner 48,000 miles 1972 SS Nothing original about it... 1977 Trans Am 6.6 all Pontiac |
I have a set of roller tipped Comp Cams rockers under mine with poly locks and they fit no problems. I've heard more than one person say the Harland Sharps fit as well like Jay mentioned.
69 Pace Car and 69 Hard top |
They will work with thicker valve cover gaskets, sometime you have to squeeze the baffles with a pair of pliers slightly, you can also machine down the posi lock slightly where it touches the fulcrum. Check how much room there is between the body and the lower portion of the built in hex nut on the posi lock, and keep around .080-.100 clearance. Some posi locks are extremly tall with more than .200-.250 in this area to the top of the rocker body. Machining the bottom of the lock off helps with the valve cover touching the lock and not allowing the cover to seat against the head.
1994 Lumina Z34, 2655lbs. 446" Small Block, Brodix Canted Valve, lenco 5 speed, 8.21/167 Best. New Bickle Cavalier, 1810lbs for 2010. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973. |
Yes, I do have baffles in mine. The Comp Cams roller tip rockers look pretty much like a regular rocker but they have the roller tip on them.
Under the Z-28 valve covers, I'm running these:
http://www.summitracing.com/parts/CCA-1804-16/ I did have to run a 5/16" thick gasket (I can supply the part number if needed). And as stated above, I had to slightly collapse the baffles using a C-Clamp (no big deal). I'm running AFR heads (older castings) and they may or may not have elevated valve cover rails. There's some trial and error here depending on your combo. Is the engine on a stand or in the car? |
#11
These are the ones I am using http://www.summitracing.com/parts/CCA-1411-16/ on top of a set of Dart Iron Eagle heads.
69 Pace Car and 69 Hard top Last edited by srode; Mar 11th, 12 at 04:36 AM. |
#12
I have the probe shaft rockers and they absolutely dont fit. We are slotting the holes, machined the lip off the seal surface, added .313" gaskets and probably at the end of the day making an aluminum spacer with some offset upward towards the intake.
All the oiling boss's where cut and baffle reworked to clear. Going through the pain because I think they are the only valve cover (looks) to run on a street car. |
#13
Crane makes low profile roller rockers that come with low profile poly locks to clear stock valve covers- i know they sell them with the self guiding tip for late model heads without guideplates, but i think they sell them without the built in guides, too.. they also sell them thru GMPP as part of the HOT cam kit with a 1.6 ratio.
you don't plan sincerity. you have to make it up on the spot. wanna hear about 20 years ago when i was too smart to know any better? |
#14
However mine I believe were the newer style with the drippers, I cut them short to clear the posi locks.
Sean 1968rs, formerly a 406 sbc, 354" SB2.2 coming soon... "Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari |
#15
I have a set of Erson roller rockers under a set of Z/28 valve covers with baffles on my our 68 vert. They clear with no problems.
| Sponsored Links | |
Advertisement | |
