chrome trim around windows, doors, and reveal molding on original 1968 - Team Camaro Tech
Restoration Corner Where originality comes first
Thread Tools Display Modes
Old Mar 28th, 12, 11:35 AM
AndTom68 AndTom68 is offline
Tom
Default chrome trim around windows, doors, and reveal molding on original 1968
Does anyone know what these are made of? Are they solid stainless steal?
Old Mar 28th, 12, 11:40 AM
Tom
Default Re: chrome trim around windows, doors, and reveal molding on original
I am working on buffing out the original windshield, back glass, and reveal moldings and was wondering if you can sand the deeper scratches. buffing only on a bench grinder is taking forever!
Old Mar 28th, 12, 12:03 PM
Fred Ficarra Fred Ficarra is offline
Fred
Tom, my 69 has all stainless molding around the "top" half of the car. I'm certain yours is the same.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
Old Mar 28th, 12, 12:11 PM
Tom
what do you mean by "top" half of car?
Old Mar 28th, 12, 03:20 PM
Mike68RS Mike68RS is offline
Mike
Tom, yes all the windows,drip rail, optional door and quarter reveals are stainless on a 68. I have a 68 rs and the rocker trim on the doors, fenders and and quarters is anodized aluminum.
I am in the middle of polishing my molding now also. I have been water sanding the stainless when I find straches that are too deep. I use an 8" sisal wheel and polish. You need a powerful polisher to get the job done.
Mike
Old Mar 28th, 12, 05:02 PM
Moonpie's Avatar
Moonpie Moonpie is offline
Mickey
I was doing a forum search on the same subject and read an excellent post about polishing the stainless. In that post the guy explained wet sanding the trim pieces. Don't immediately recall the grit though it was rougher than I would have expected. If you can get the majority out from wet sanding it will make the job a lot easier. Stainless is just tough to polish.
Here's another idea, one I may do. Chrome platers have to polish stuff before they can chrome a piece. They have big boy polishers and lots of experience if you can get them to not bend a thin piece of trim. Ask around a few shops and see what they would charge to polish your trim.
Old Mar 28th, 12, 08:05 PM
68camaroz28 68camaroz28 is offline
Chick
Maybe some of the issue you may be having is the flash chrome covering the stainless pcs.. I have been told once that is removed rework and polishing goes much easier. Searches can bring up a ton of material on the subject. JohnZ has talked about the flash chrome many times.
Chick
68Z28-Orig. Engine/Drivetrain
69Z28-Orig Eng & GM Cross-Ram Pro-Tour
69 Nova L34 Father/Son
69 Nova L78 Surv purch-new
2015 Z28 Our 68Z Restoration http://www.camaros.net/forums/showthread.php?t=182584
Old Mar 28th, 12, 08:18 PM
TModel66 TModel66 is offline
Daniel
I tried polishing a center cap that was rough. I broke thru the flash chrome and it is yellow hue to it. Don't look good at all. It's sitting in my computer room on the shelf as an ornament.
Old Mar 28th, 12, 08:24 PM
Sauron67MM Sauron67MM is online now
Scott
I've straightened and polished trim before. There are countless threads on this mindless, boring job. Deep scratches are removed simply by using a coarser grit and working up. When you cut through the flash chrome there is a noticeable appearance difference. Live with it, take it all off or have it flash chromed again.
Old Mar 28th, 12, 09:19 PM
68camaroconvert 68camaroconvert is offline
Team Member
Bob
There are polishers who advertise on e bay selling restored stainless trim. I have sent some of my larger dented pieces ( top of door stainless on a 68 convertible ) for restoration.
If the scratches aren't to deep I have used a cotton wheel and stainless polishing compound available at home depot /lowes.
Click image for larger version
  #11
Old Mar 28th, 12, 09:25 PM
larryh56 larryh56 is offline
Larry
This is a pretty good overview I saved: http://www.caswellplating.com/buffman.htm
68 RS Coupe 327/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
  #12
Old Mar 28th, 12, 09:30 PM
Steptoe Steptoe is offline
Steps
Stainless is a very hard material...so using your normal cut an polish stuff is next to useless...Source some proper stainless polishing rouge coasres meduim and fine grades....comes in sticks or slabs...and is suprisingly cheap
It is also ideal for polishing Aluminium using kerosene (paraffin oil)
Bench ginder is ok to use BUT your normal run of the mill 1/2 hp and a 8" diameter polishing pad only just makes the grade for Aluminum....a 10" polishing pad and 3/4 or 1 hp does get the job done . and a bit slow on the stainless.
  #13
Old Mar 28th, 12, 10:30 PM
Garfields Maro Garfields Maro is offline
Garth
Yes, with the proper buffing wheels & compounds, you can sand the deeper scratches out first. For stainless, after finish sanding at 400 grit, a Sisal wheel is used along with Emery compound. Usually 2 passes will eliminate the sand scratches and you're ready to move on to a Spiral/Ventilated wheel with Stainless compound. 2 or 3 passes and you can finish with a Loose Section wheel and White Rouge compound. All this stuff is available through Eastwood along with tips and techniques pamphlet if you buy as a kit.....or as Scott would say, skip Eastwood and have your jobber fix you up with the needed supplies. You need a grinder with 1/3hp min. Bigger grinder can use bigger/thicker buffing wheels.
Center cap as in Rally Wheel ? Those are regular chrome plated. Not alot you can do with scratches. Certainly no sanding. Can use the last 2 steps (wheel/compounds) as above, starting with Spiral Ventilated/ Stainless, but need to avoid over doing it and buffing through the plating.
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
  #14
Old Mar 29th, 12, 02:57 AM
Scott
One of the few things they don't get involved in. But yes, buffing supplies, specialty tools as well as everything else needed in restoration and auto body can be purchased outside Eastwood. Big difference between a real metal buffer and a bench grinder.
Here is one source, there are others of course:http://www.caswellplating.com/buffman.htm
  #15
Old Mar 29th, 12, 04:49 AM
gphusker gphusker is offline
Greg
From working on aircraft we do polish stainless and we usually sand it with 500 grit if its decent and buff it with a product called Nuvite IIc. Great stuff! Not sure where you can get it from but it cuts great and breaks down as you use it so there is no need for a second compound. Bottom line is stainless is hard to polish no matter what.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Restoration Corner      Current Topic: chrome trim around windows, doors, and reveal molding on original 1968
Location
Location
First Name
Human Verification
