Transmission output shaft turns in neutral - Team Camaro Tech
Old Apr 20th, 12, 06:21 PM
jeffscamaro jeffscamaro is offline
Tech Team
Jeff
Default Transmission output shaft turns in neutral
Is it normal for the output to turn on a manual transmission when in neutral.??? Thanks!!
Old Apr 20th, 12, 06:41 PM
srode srode is offline
Steve
Default Re: Transmission output shaft turns in neutral
yes
69 Pace Car and 69 Hard top
Old Apr 20th, 12, 10:01 PM
MEJ1990TM MEJ1990TM is offline
Tech Team
Mike
Yep. Especially a fresh build that has yet to be filled with oil. If you have the trans in neutral ,and you're holding the output shaft, and it will still want to spin there is something wrong. Most likely a fresh build that has a synchro ring stuck to one of the gears.
1970 SS 454 Chevelle (LS5, M22, 3.31 12 Bolt)
1971 Chevelle Malibu (350, M22, 3.31 12 Bolt)
There's no shift like a power shift.
Some of the old junk
http://s160.photobucket.com/albums/t164/MEJ1990TM/
Old Apr 21st, 12, 07:35 AM
Tech Team
Jeff
Thanks for the replies. Figured it had to do with enertia as the output shaft isn't moving all that fast.
