68 ss turn signal light - Team Camaro Tech
Old Apr 22nd, 12, 04:09 AM
monaroman monaroman is offline
Darren
Default 68 ss turn signal light
Hi there,
I have done a search which did help.
Drivers side turn signal is not flashing/on at all. Rear indicator stays on solid.
Park lights work (L&R), hazard work on all except drivers side. Headlights on there is no problem other then drivers side indicator not on/flashing. Revers lights operational also.
Got into dash area no loose wires made sure all connectors were tight. I noticed drivers turn signal indicator in cluster not lite also.
Resistance of globe 2.2 ohms and .5 ohms, flasher 48 ohms and constant 12volts on blue wire at globe once i voltage tested to ground.
I have swapped bulb from passenger turn signal with same outcome.
I did find a bad ground from housing to radiator support and will repair.
Anyother possable solutions are welcomed.
Thank you.
Old Apr 27th, 12, 01:25 PM
r_w r_w is offline
Default Re: 68 ss turn signal light
Originally Posted by monaroman View Post
Hi there,
That would do it.
______________
Life is too short to drive cars that suck.
'67 Convertible
http://www.novitatech.com
Old Apr 27th, 12, 02:13 PM
Everett#2390's Avatar
<Jake 68's Rule
Turn signal indicators are hooked in parallel to front bulbs at the firewall connector.
You might do a continuity check and compare pass side ohms, LBL, with and without turn signal indicator to the drvr side, DBL wire.
You could measure from turn signal connector on steering column.
I would imagine you will see a difference in resistance values between the two sides.
Once you find the difference, you can do a continuity check on the individual wire.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
