ZZ383... Manifolds or Headers? - Team Camaro Tech
Camaro Tech General Tech Area
Old Apr 27th, 12, 01:32 PM
Spicoli Spicoli is offline
Ben
Default ZZ383... Manifolds or Headers?
Getting ready to put my ZZ383 in my 4-speed 69 and I need to make a decision on exhaust. Should I run a set of Doug's D368's (or other brand) or manifolds? I know people have good luck with Doug's, but they interfere with reverse lockout. What would be a good manifold that would fit, or do you recommend something else?
69' SS/RS, ZZ383, Muncie M20, 12 Bolt Eaton Posi
Old Apr 27th, 12, 04:46 PM
69huggero 69huggero is offline
Scott
Default Re: ZZ383... Manifolds or Headers?
I have a set of hooker super comps and they work great. I would go with headers over regular manifolds from a hp and sound standpoint
Old Apr 28th, 12, 04:38 PM
Ben
Are they on a ZZ383? If so, what part number are you running?
Old Apr 28th, 12, 06:07 PM
Scott
Yes they are on a 383. I don't recall the part# as I put them on about 4 years ago. I ordered them from jet hot.
Old Apr 29th, 12, 07:23 AM
Ben
Thanks buddy... I will check into them.
Old Apr 30th, 12, 06:41 AM
novaderrik novaderrik is offline
Hedman Hedders are cheap and built well.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Apr 30th, 12, 07:18 AM
Matt 69 Matt 69 is offline
Matt Polidora
FYI,Hooker super competition headers WILL allow you to retain the reverse lockout linkage on your car.If that is your only determining factor,I would go with the headers over the manifolds.
1969 SS Garnet Red X55 350 Factory 4 speed
12 Bolt 3.55 Posi
Old Apr 30th, 12, 09:11 AM
zdld17 zdld17 is offline
Don
Using the D 368 from Dougs, might leave the bubble wrap on them until you get them up into the engine bay. Needs lots of floor space, they seem to go in , straight up on the left side. Right is no problem
You may need to use the shorty oil filter , equilivent to AC PF 454. Little tight going in and out.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
