Door Windlace Screw ID - Team Camaro Tech
Old May 6th, 12, 05:06 PM
Andrew69's Avatar
Andrew69 Andrew69 is offline
Andrew
Default Door Windlace Screw ID
What type and size screw goes into the corner at the front of the 1/4 side glass, top of the windlace area? How in the world do you align everything up to get the screw into the original threaded hole?
Click image for larger version
Name:	Door Lindlace.jpg
Skunk Works
302DZ, M22W Muncie, 12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159 (Formally known as X33D80)
Old May 7th, 12, 02:50 AM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: Door Windlace Screw ID
A #6 x 1/4 flathead sheet metal screw.
Maybe 5/16 inch long. You could also use an 'undercut' flathead screw, meaning the backside of the screw head has been cut, not a complete 'V'.
If you remember the size of screwdriver used to remove, a #1 Phillips tip goes with a #4 screw, where a #2 Phillips tip goes with #6 to #10 screw.
Trim hole could be in the wrong position, or trim needs more movement.
Measure the length between holes of both trim/windlace/fuzzy and qtr panel to see if they match. If not, choose one piece to drill a new hole.
Before installing screws, run your screwdriver across a speaker magnet to magnetize the screw to the screwdriver. Once it falls into the qtr panel, its gone.
This magnetizing will only work if you use carbon steel screws vice stainless steel screws, then use bubble gum. Use antiseize on the threads to protect from rusting.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old May 10th, 12, 05:34 PM
Andrew69's Avatar
Andrew
Done. Thank you very much for your help Everette.
Name:	Door Windlace 2.jpg
Skunk Works
Old May 10th, 12, 06:15 PM
Sauron67MM Sauron67MM is offline
Scott
That's not the right screw. I don't have one for immediate viewing but it's not chrome, the head is flat and smaller.
Old May 11th, 12, 05:38 PM
Andrew69's Avatar
Andrew
Done (I think). A couple of screws from the local hardware store. They had flat black screws of this size but the shortest was about 1" long. These are a kind of antique bronze color. Dark, but not black. Are they a more original GM appearance?
Name:	Door Windlace 3.jpg
Skunk Works
Old May 11th, 12, 07:23 PM
Scott
Nope, that's an oval head and the head diameter is too large. I can provide a photo but not right away. I thought I posted one on CRG but it's been a long time.
Old May 12th, 12, 12:27 AM
Garfields Maro Garfields Maro is offline
Garth
c'mon...oval headed ??....probably just sunk into the rubber more on top & bottom.
Well, I just looked at mine and pretty sure they're not OE....look very similar to your latest Andrew, only not bronze. If I recall, had to use a larger screw as the metal there aint much and what I had wouldn't tighten down. Suspect you'll have the same problem if you try to use an OE screw.
Scott, is it the same screw as used for 68 reveal molding/outer fuzzy and the wire loom shields along the rockers ? If so, I've got a pic handy if needed....
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old May 12th, 12, 03:06 AM
Scott
I did not name them, the industry did. Look it up. The domed/convex head you see is referred to as oval head. Photos in AMK catalog but not identical to original. Terms flat and domed are also used there. Flat head means what the name implies, and that screw head is not flat. Clearly shown by the shadows on the head.
Same as 68 reveal molding, self tapping also. Can't recall exact dimensions of wire cover screw. Other molding screws are not identical to original but have a smaller head diameter also.
Old May 12th, 12, 04:24 AM
Andrew69's Avatar
Andrew
Yes, that is an oval head screw. Good eye Scott. So the preferred screw is a flat head typically used in a countersunk hole? They have those too, in a flat black color. Their cost is about $0.20 each so it isn't breaking the bank to replace them.
I just don't see how the screw head can be much smaller. It will just pass through the slot and retain nothing.
Skunk Works
Old May 12th, 12, 04:52 AM
Scott
It's barely larger than the slot. If the repro slot dimension is too large you may have to use a different screw. Some wheel well molding screws have small heads. They have a different profile but are flat so as not to stick up compared to the oval head you have in there now. You are now running the risk of enlarging the hole. Hardware store screw head to thread dimension relationship is standard. The correct screw head's diameter is not. So you may find the right head diameter but incorrect thread size. I have one correct screw on hand and can probably dig more up. You can have them if I find another one.
Old May 12th, 12, 02:00 PM
Garth
Man, I forgot these photos are so blurry.
Is this the correct screw ?
Old May 12th, 12, 04:21 PM
Scott
Affirmative.
Old May 12th, 12, 06:21 PM
Garth
As mentioned, those were also used for the wire harness sheilds along the door opening...or they were on my car anyway. Might be fairly easy to rob one to see if it'll work....I'm guessing it won't tighten down now after using slightly larger screws.
Old May 12th, 12, 06:26 PM
Scott
He can take a piece of stainless, bend it and put it in the hole to provide more meat for the screw to hold. Burping with a mig aside.
Old May 13th, 12, 04:29 PM
Andrew69's Avatar
Andrew
I gave it one more try and picked up a pair of black colored flat head screws. The holes are not stripped and the screws pull tight, that is not a problem. The screw heads might be a little too large diameter but this is going to have to do. Thanks for you help guys.
Name:	Door Windlace 4.jpg
Skunk Works
