Big Block Chevy Piston to Valve Clearance - Team Camaro Tech
Thread Tools Display Modes
Old May 18th, 12, 12:12 PM
Sixty7camaro Sixty7camaro is offline
Tech Team
Keaton
Default Big Block Chevy Piston to Valve Clearance
What dimension should I be looking for both the intake and exhaust valve to piston clearance? The cam is degreed in and I'm using a used head gasket. I measured about .093" clearance between the piston and intake valve the first time I checked. I'm going to do it all over again to be sure. I've read where .080 is good but I want to be sure. The motor has steel rods by the way.
Old May 19th, 12, 09:42 PM
1962vette 1962vette is offline
Paul
Default Re: Big Block Chevy Piston to Valve Clearance
Comp Cams BBC
Piston to valve clearance must be verified –the minimum clearance is .080" on the intake side and .100" on the exhaust side. The easiest method of verifying piston-to–valve clearance is to check using modeling clay on top of one of the pistons.
See the COMP Cams® Master Reference Guide or www.compcams.com for detailed instructions on using this method.
Old May 20th, 12, 03:29 AM
97Z4C 97Z4C is offline
darrell
i always use .090 intake and .110 on exhaust- my opinion is 80 and is not enough on performance and high rev apps-when using larger valves, always chek intake valve to cylinder wall clearance
Old May 20th, 12, 04:46 PM
Z15CAM Z15CAM is offline
Ron
Valve to Piston Clearance depends mostly on Size of Valve reliefs and Dia of Valves and Inversely Proportional to Duration of the Cam - That is the longer the duration the tighter the Valve to Piston Clearance. Basically do not worry about Valve to Piston Clearances with Cams under 300 Advertized Duration Degreed per Specks in STK OEM Specked Engines as Cam and Piston Manufactures take this into account. Ensure when Clay Modeling that you have enough Piston Valve Relieve Diameter when running Large Dia Valves.
Valve to Piston Clearances are closet when the Intake 1st Opens and the Exhaust Valve Closes - Advancing or Retarding the Cam by 2 Degrees generally changes the clearance by .010" respectively.
Head Gasket thickness, Milling either Deck or Heads change the Valve Seat Height and affect Valve to Piston Clearances - Generally Lobe lift has very little affect unless you running extreme (310+) durations.
Pending Cam, I've run .080"/.100" Int/Ext Clearances with 2.19/1.9" Dia Valves and TRW or Speed Pro Domed Pistons to over 7000rpm in SR BBC Mills without issues. Some will run clearances as tight as .060"/.080" (Not uncommon in SBC's).
As Darrel mentions Check Intake Valve to Cylinder Bore Clearance especially when running a 396 Bore and Large Dia Intake Valves in which case one may have to Fly Cut Clearance in the upper Edge of the Cylinder Bore around the Intake Valve above the Combustion Ring Stop Position.
Z15CAM - There was a Viper in my Rear View
This was my 70 1/2 Z28
http://www.flickr.com/photos/28082975@N04
Old May 23rd, 12, 10:36 AM
Tech Team
Keaton
Since I'm close at .093", are thicker head gaskets available to increase the clearance?
Old May 23rd, 12, 03:32 PM
casey69z casey69z is offline
Casey
You didn't tell us what thickness your current head gasket is. Also are you using a solid lifter to check clearance as hydraulic will give you a false reading.
Old May 25th, 12, 09:30 AM
Tech Team
Keaton
I did not use a solid lifter in my check. I ordered two solid lifters that will be here tomorrow so I can do this again. The head gasket is a Fel pro 1017-1, with a compressed thickness of .039". I do have two Fel pro 1017-2 head gaskets also, with a compressed thickness of .051".
Old May 25th, 12, 01:08 PM
zdld17 zdld17 is offline
Don
Keep in mind while your are playing with head gasket thickness, you also change your piston to head quench. I look for about .040. I am 0 deck so the Felpro 1010 worked well for me on a sbc. Specs on a bbc may be a little differant.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Big Block Chevy Piston to Valve Clearance
Location
Location
First Name
Human Verification
