engine is sluggish - Team Camaro Tech
Troubleshooting Diagnosing problems done here.
Old Dec 10th, 01, 03:20 PM
78lt 78lt is offline
Tech Team
Post
I just installed a Holley 750 on my 406 with twisted wedge heads. When I run it through the gears it is fine, but when I floor it in third below 2500 rpm it feels sluggish. When I am above 2500 it pulls fine. Do I need a lighter secondary spring or a heavier one?
Old Dec 10th, 01, 03:35 PM
DjD's Avatar
DjD DjD is offline
Dennis
Post
Sluggish or a bog? If it bogs then maybe a lighter spring would help. What cam are you using? It may not make power before 2500 and third gear can't over come being out of the power zone like 1st or 2nd can.
...Dennis
"The '69, the '96 & the club"
Old Dec 12th, 01, 06:38 PM
Cameron Cameron is offline
Post
I have a 406 with Trick Flow 23 degree heads, Performer RPM intake, XE274 camshaft, and a 750 Holley that I just put on last weekend. I currently have the white spring (lightest spring you can get) on the secondary diaphram. I have great low end response. Even with the 2.73 rear end and the four speed, mine doesn't bog at any RPM. I can easily lug mine around at 1200 RPM in fourth gear. I can stomp the gas at 1300-1500 RPM in first gear and melt the right rear tire (posi needed bad).
What are your cam specs? What kind of intake do you have? What gears are you running in the rear? A big cam and a single plane intake with high gears would perform as you describe. What did you have on it before and how did it perform?
When you say "bog", what do you mean? Does the car accelerate good in third then bog when the secondaries open? If that were the case, you would need a heavier secondary spring. Or, does it just not want to gain RPM? If that were the case, you might want to try a lighter secondary spring and/or look at the way your carburetor is tuned more closely. Another possibility is, like Dennis suggested, your engine, with that particular carburetor might not be in its power band below 2500 RPM. The higher gearing of third gear could just be magnigying the problem.
