Kick Panel Installation - Team Camaro Tech
Thread Tools Display Modes
Old Jun 4th, 12, 08:59 AM
USN1969SS USN1969SS is offline
Dave
Default Kick Panel Installation
Just a quick note ...I read many "Kick panel removal/installation" posts but didn't come across the way I did it (after many a struggle trying other ways), may have been posted, I just didn't see it. Any how, mine came out and went in very easy simply by pulling the bottom out first and the top came out after getting to a good angle. Putting in I just put the top in while panel bottom was at a good angle out and they went right in. This is a non ac car if that matters. The pillar post portion will be contourted but mine did not break. Did not remove heater core, just the under dash vent channel and parking brake.
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
http://www.camaros.net/forums/pictur...pictureid=4730
Old Jun 9th, 12, 08:46 PM
jcfcamaro jcfcamaro is offline
jared
Default Re: Kick Panel Installation
Make sure you leak test them with a water hose on the outside before you call it good !!! I put mine in,and then tested them,and both leaked a little, so I took them back out and added more chauk, then re tested and was alright !!!
Old Jun 10th, 12, 11:26 AM
Unreal Unreal is offline
Gary
That's good information. The kick panels are the cause of many brand new cuss words.
Old Jun 10th, 12, 03:03 PM
Garfields Maro Garfields Maro is offline
Garth
Yeah, sounds like it might be. I'd say that technique isn't tried much for fear of breaking the pillar section, but I must say, even after 40+ yrs, mine seemed pretty much indestructible....able to withstand anything I had to dish out anyway !
Anyone ever break that pillar section off a kick panel ?
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Jun 10th, 12, 06:45 PM
Steiner Steiner is offline
Steiner
I had to peel the passenger side body seam part of mine all the way off not long ago so I could pry the kickpanel back enough to get my hand in there and get the door switch wire plugged back on. Didn't even remove the screws around the vent. Wasn't about to pull that thing out again especially with as much duct sealer as I put on it last time. That long piece running up the door is usually pliable enough at least on originals that you can get it out without moving the kickpanel at all. Don't try it if you painted them though.....crack crack crack crack.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Jun 11th, 12, 05:54 PM
Moonpie's Avatar
Moonpie Moonpie is offline
Mickey
I need some new ones. I've worn out all the ones I know.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: Kick Panel Installation
Location
Location
First Name
Human Verification
