rear leaf spring rebuild - Team Camaro Tech
Thread Tools Display Modes
Old Jun 6th, 12, 02:19 PM
AndTom68 AndTom68 is offline
Tom
Default rear leaf spring rebuild
does anyone have instructions on rebuilding leaf springs? I have all pieces but not sure how to put together
Old Jun 6th, 12, 02:22 PM
camarodude67 camarodude67 is offline
Default Re: rear leaf spring rebuild
Why not just buy new ones they are cheap....
Jeff G.
Old Jun 6th, 12, 02:43 PM
Tom
I already bought a used pair and took them apart and painted. bought all parts to rebuild but not sure how to get them back together
Old Jun 7th, 12, 07:32 AM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
Tom
Hopefully you marked all the leaves as to which spring they go with and also front to rear. Take some time and fit all the leaves together making sure there won't be gaps inbetween them when you tighten them up. If you have issues with a couple not fitting well you can rearc them to fit with a one handed sledge hammer and anvil. It's not rocket surgery, but takes a little experience.
The center bolt draws all the leaves together. The head should be on the top side of the spring. Get it good and tight and then give the end of the bolt a couple whacks with a hammer so the nut won't be able to back off.
If they provided clamps, use C-clamps or big vise grips to squeeze all the leaves together as tight as you can, where the clamp will go, so when you install the clamp it won't be loose. When you release the C-clamp the leaves will expand a little against the clamp making everything nice and tight. Should be a clamp front and rear for each spring.
Mark
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
http://www.camaros.net/forums/member.php?u=3230
Old Jun 7th, 12, 09:05 AM
jl8z28 jl8z28 is offline
Guy
where do you get the correct center bolts, I dont see anyone that lists them.
Old Jun 7th, 12, 02:01 PM
mbrekke's Avatar
Mark
Check your local brake/suspension shops that rebuild truck springs.
Mark
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: rear leaf spring rebuild
Location
Location
First Name
Human Verification
