Master cylinder - low fluid in rear reservoir? - Team Camaro Tech
Thread Tools Display Modes
Old Aug 3rd, 12, 06:50 AM
DarrenX33 DarrenX33 is offline
Default Master cylinder - low fluid in rear reservoir?
Having a strange problem with my master cylinder. Recently pulled my 69Z out of storage and found that the brake pedal was going to the floor. I pulled the cap off and found that the rear reservoir was near empty. The funny thing was that when I pulled the cap off a lot of fluid spilled over and out of the front reservoir, almost like the rear fluid was going into the front.
I do see a small drip line down the booster. But when I separate the master from the booster it seems dry so I don't think its coming out the back of the MC when I push the pedal. Wheels cylinders look dry and nothing visible on any of the brake lines running to the rear.
Proportioning valve???
-Darren
Old Aug 3rd, 12, 07:12 AM
parkbrau's Avatar
parkbrau parkbrau is offline
John
Default Re: Master cylinder - low fluid in rear reservoir?
I'm just guessing here...But did you have the emergency brake on all the time? If yes, that may have forced fluid from the back reservoir to the front. Sounds like a MC rebuild would not hurt.
John, 69 Base Coupe, Rallye Green
69 L78 Rallye Green Nova
Do This. Get a job and in 14 days you will come into some money!
Old Aug 3rd, 12, 08:12 AM
I topped it off and drove it around town and it proceeded to empty again.
When I restored my car in the early 90's I sent the master out to be re-sleeved. I wasn't thinking I needed it again. But maybe?
-Darren
Old Aug 3rd, 12, 09:29 AM
parkbrau's Avatar
John
Then you have to be able to see where the fluid is dripping or leaking from if its that noticeable.
Old Aug 3rd, 12, 11:48 AM
I agree. One would think but nada.
-Darren
Old Aug 3rd, 12, 12:10 PM
Vintage 68's Avatar
John
Wink Re: Master cylinder - low fluid in rear reservoir?
If the fluid is transferring from the 'rear' reservoir to the 'front' - then the problem is internal to the Master cylinder
The secondary cup seal(s) have been damaged or failed ...
Rebuild/replace the master.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Aug 3rd, 12, 03:27 PM
Steptoe Steptoe is offline
Steps
How long has the car been sitting... storage is bad on brake seals...MC and wheels.
Have seepage marks down the booster but no signs behind the MC seals....
Check inside the booster for fliud... it may need emting of brake fliud.
Is there air when u bleed the brakes?
Does sound like what John above describes.. replace rebuil MC, and caution with calipar and slave seals... storage, plus extra pressure from a new MC usually blows those over the next couple 1000 miles to.
Old Aug 3rd, 12, 09:28 PM
Hardcore storage since last November. It's usually out by april but I needed it in 3 mos longer than usual. I'll check into those things.
-Darren
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Master cylinder - low fluid in rear reservoir?
Location
Location
First Name
Human Verification
