Detroit Speed RS light conversion? - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Sep 12th, 12, 06:25 AM
ENP ENP is offline
Default Detroit Speed RS light conversion?
I installed my new RS kit with the Detroit speed setup. Car is a non RS car been converted to RS. Do I need to install the headlight door bellcrank over-center spring? The springs are super tight.
Click image for larger version
Old Sep 12th, 12, 05:42 PM
Mike68RS Mike68RS is offline
Mike
Default Re: Detroit Speed RS light conversion?
Per DSE instructions. "On the headlight door assembly, there is an over-center spring installed and it must be removed"
Mike
Old Sep 12th, 12, 05:45 PM
ENP ENP is offline
Mike
I must have overlooked that. I didn't see it in the instructions.
Old Sep 13th, 12, 05:11 AM
Mike
No problem. Let us know how the install goes. I'll be installing mine in a couple months.
Mike
Old Sep 13th, 12, 10:53 AM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
Can the DSE conversions be used with 67 and 68 RS headlight modules or just the 68?
I have thought of converting my 67 to RS and would use the 67 kit that is already electric but I understand that even these can be troublesome. I was thinking of the DSE solution and started wondering if I need a 67 or 68 modules to use them. I have found a 68 conversion on my local craigs list for a 68 that is complete. Person does not know if a re-pop or GM but it can be bought for $500.00 complete with the Grill, trim, actuators etc. Not a bad deal.
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Detroit Speed RS light conversion?
Location
Location
First Name
Human Verification
