| Team Camaro Tech Current Topic: Right turn knock?? | ||
| Troubleshooting Diagnosing problems done here. |
OK I need some help here, when I make a sharp right turn I hear a knock but I'm unable to see anything that is making contact. If I make an easy right turn there is no sound, Any ideas?
| Sponsored Links | ||
Advertisement | ||
Check your upper and lower A arm bushings,also check the 2 bolts where your alignment shims are they could have been left loose. Hope this helps
I agree with Mr C. I had a friend with a 79 Z/28 that did the same thing. One of his upper A-Arm bushings was gone. The car bounced alot to, but he got a hand on it.
------------------ Steve 67 SS 396,4-sp 67 RS 327,4-sp 72 RS 350/350 69 4X4 suburban 350,4-sp 73 3/4 ton 454/400 Stevo Camaro's Toy Our Muscle Cars |
It's interesting because driving down the road is just fine and a slow right turn is OK, it's just when you make a slow right like into a driveway that I hear a knock.
Everything looks OK it's just too cold right now (-9 to 25) to lift the front end and check it all out so I thought I'd get your opinions and when the weather co-operates do a quick check of the system. I appreciate your replys. |
Check the ball joints and the shock mounting bolts. My car had a noise like that and turned out to be the upper shock attachment.
------------------ Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench |
Just for thought when you are turning the sway bar is under force and could have a bad end link or frame bushing that is bad or even a broken frame bracket.
What is the easiest way to check the bushings in tghe A-arm. Everything else looks good but there is a 1/4 space in the bushing between the edge of the bushing and the frame.
Make sure the front suspension has been well lubed. Even if this doesnt help the problem, it doesnt hurt to check it. I had a friend who had a similar problem and it turned out that there was hardly any grease in the ball joints ot tie rod ends.
| Sponsored Links | |
Advertisement | |
