Setting Fast Idle speed screw on Holley 650dp - Team Camaro Tech
Thread Tools Display Modes
Old Oct 4th, 12, 06:58 AM
DenRS's Avatar
DenRS DenRS is offline
Default Setting Fast Idle speed screw on Holley 650dp
Hi guys,
I got picked up a 650dp. Came with an electric choke kit in the box which I just installed. My question is what would be a good starting point to set the fast idle speed screw? How many turns in? When i picked up the carb, the manual choke was zip tied open so I don't have a reference starting point.
I realize I need to install the carb and start the car to see where I'm at, but I just worried about firing up the car and having this thing rev to the moon.
1969 Camaro 350, Trickflow heads, ST-10 4spd, Hotchkis suspension, Baer SS brake kit, moser 12bolt
Old Oct 4th, 12, 07:21 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Default Re: Setting Fast Idle speed screw on Holley 650dp
I'd back it off all the way, and then just nudge it a little. You can always adjust a little at a time once it's idling and you've set the idle mixtures.
Is it new? It may already be set for a decent idle speed. They're usually set to run straight out of the box.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Oct 4th, 12, 07:25 AM
Everett#2390's Avatar
<Jake-68's rule
Generally, 1400 rpm is the spot.
Trial & error is the key.
But, the easiset way to adjust is notice present rpm with fast idle cam in place, shut engine off, WOT and screw is right there to adjust, make adjustment, set fast idle cam again, start engine, and check rpm. Sometimes, you may get away with 1200 rpm.
Old Oct 4th, 12, 09:03 AM
DenRS's Avatar
Carbs not new. Its 7-8 years old carb but it just came off my brothers Nova. He went through the carb about 6 months ago and it was running perfect on his zz3 in his Nova. He pulled it off a couple months ago to put on a 680 vac secondary quickfuel carb since he has a auto.
So its best to start with the screw only one or two turns in and go from there. Holley's instructions don't really give a starting point other than it should be pretty close from the factory.
Old Oct 4th, 12, 09:28 AM
DjD's Avatar
DjD DjD is offline
Dennis
I wouldn't adjust the fast idle until after you have the choke installed on the carb and the carb on the engine and running... The fast idle isn't going to cause the engine to rev to the moon, it might be higher than you want it to be but you can release it manually or shut the engine off and adjust it down some...
...Dennis
www.camaroslimited.com
Old Oct 4th, 12, 10:02 AM
DenRS's Avatar
ok thanks.
Old Oct 4th, 12, 10:46 AM
tiller83 tiller83 is offline
Tech Team
hans
I have a holley 670 avenger on a 351 and from the factory had to back down the choke/fast idle. I'd play with it assembled(elec.choke installed) and adjust it to hold the throttle just past curb with the choke fly barely closed (not on the engine). You may want to warm up the engine with your pressent carb. and then swap to set curb on new carb. Then remove to play with fast idle screw. Is difficult to reach unless you have a high rise intake or alot of patience and a flexible screwdriver.
Though I found the 670 to be under powering my engine it's efective enough and gets slightly beter fuel economy than a 700 or beter.
Old Oct 4th, 12, 11:02 AM
DjD's Avatar
DjD DjD is offline
Dennis
Don't even open the screwdriver drawer... Use a small 1/4" (I believe) wrench. Try an ignition wrench, shut the engine off, open throttle and turn screw...
...Dennis
Old Oct 4th, 12, 11:56 AM
Steptoe Steptoe is offline
Steps
"factory setting for most carbs.. be a briggs and stratten or stil chainsaw is usually 1 1/2 turns choke off and same with the mixture screws.
To get into rage on both often means dialing in t5he idle circits by adjusting the seconday butterflies...little screw on the under side on opposite side to throttle linkages..its adjustable while engine running.
Never set butterflies full closed..causes jamming and associated issues.
Old Oct 4th, 12, 12:23 PM
DjD's Avatar
DjD DjD is offline
Dennis
What does any of that have to do with the chokes fast idle mechanism that holds the primary throttle blades open when the choke is on?
...Dennis
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Setting Fast Idle speed screw on Holley 650dp
Location
Location
First Name
Human Verification
