| Team Camaro Tech Current Topic: 1987 2.8 MPFI CAMARO HELP!! 2000 -3000 RMP IDLE | ||
| Troubleshooting Diagnosing problems done here. |
My 2.8 MPFI has an idle of 2000 RPM'S + in park . I was told i have a massive vacuum leak , but they could not find it? The ECM code is 32 EGR failure .The car shakes and moves around at low idle . Could it be a leaking intake manifold gasket? I was able to cross the MAF sencor wires , ground to signal.this droped the idle to 500 + 950 rpm.
But just a temp fix i got a ECM code 34 MAF/MAP sencor too low. No other codes but them. Please help [This message has been edited by BIGMAN (edited 05-29-99).] [This message has been edited by BIGMAN (edited 05-29-99).] |
i repaired the car my intake manifold gasket had blown up into the valve cover makeing the car take air from the valve cover and bottom of the motor i have a normal idle now
