Hood alignment - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Oct 18th, 12, 08:38 PM
code 55 69 code 55 69 is offline
Tech Team
Bob
Default Hood alignment
I want to remove the hood from my 69, so i can detail the hinges ( i believe they should be painted natural color? ) but am afraid i wont get hood aligned , its perfect now, any tips other than just marking the hinges?
Old Oct 18th, 12, 08:47 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Default Re: Hood alignment
Mark the hinges and also use a heavy masking tape around all the edges of the hood/fenders/cowl/ etc so you don't scratch anything.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Oct 18th, 12, 08:50 PM
Tech Team
Bob
Thanks Michael, the tape is a great idea, you think it will line up perfect just by marking the existing location of hinges to hood ?
Old Oct 18th, 12, 08:55 PM
Michael Gekko
Theoritically, yes. But it's the execution that is so important.
Go slowly with it as there may be shims between the flanges of the hinges and the hood. Make sure you identify which ones came from where if they have been used as they could be different in size.
Old Oct 18th, 12, 09:59 PM
Steiner Steiner is offline
Steiner
I usually combine what Michael said and use masking tape around all sides of the hinges as my marking method, and mark the location of the bolt washers although if you're going to detail the hinges that'll be gone. One side of the hinge is tough because it's a bend but the other three are sharp. That way you're left with a nice little box where it should go. Best tool is another person to help. Even after reinstallation you may have to leave the bolts a touch loose and bump it around.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Oct 18th, 12, 10:42 PM
Tech Team
Bob
Thanks alot guys, i will do it this weekend
Old Oct 19th, 12, 04:15 AM
Unreal Unreal is offline
Gary
And, if you care, the originals were gray phosphate, not natural. You can buy very expensive phosphate-looking paint from the resto houses, or you can phosphate them yourself for $20-30 (haven't priced the chemicals in awhile) You can buy them from Palmetto Enterprises in South Carolina. If interested do a search, the procedure has been discussed here many times. It's really easy.
You could also send them out for phosphating, for$100 or so.
Old Oct 19th, 12, 04:18 AM
Gary
I think you need to mark the hinge location on the fender, too. Been awhile, but I think there's a little variation there, too.
Old Oct 19th, 12, 08:25 AM
Tech Team
Bob
Thanks Gary, im using "Goodson grey phosphate" paint.
Old Oct 21st, 12, 01:56 PM
Tech Team
Bob
Just completed the hinges restoration & thanks to your tips it looks great & i even aligned hood better than it was...thanks again
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Hood alignment
Location
Location
First Name
Human Verification
