Muncie w/ "U" - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Oct 21st, 12, 10:31 AM
DT DT is online now
Donny
Default Muncie w/ "U"
I have a Muncie M20 laying around with the first letter U stamped as part of the vin# I guess. What plant is "U". Is this Pontiac or Olds??? Thx
396 X66 LeMans Blue, M20, 373 ...
Old Oct 21st, 12, 06:34 PM
67Carl 67Carl is offline
Carl
Default Re: Muncie w/ "U"
Are you sure it's a U? I'm definitely not a Muncie expert but I believe the letters in the serial or VIN number are "P" for the 4 speed made at the Muncie plant or M for the 3 speed. Other alpha characters are for the month it was made, so they would only be the first 12 characters (A to T) of the alphabet. I found this stuff out today as I'm decoding my Muncie to get ready to sell it. Lots of info out there on the various markings. If I've stated something incorrectly someone will speak up.
1967 350, Hurst TKO 600 5 speed, 12 bolt 3:55 posi, RS added
http://photobucket.com/1967_Camaro_Carl
Gone but Not Forgotten: 1970, born with a 6cyl, 350sbc transplanted in
http://photobucket.com/Carls1970Camaro
Old Oct 21st, 12, 06:59 PM
bertfam bertfam is offline
Ed
U is for Lordstown, Ohio. They built full size Chevrolets and Pontiac Firebirds. We need the full VIN before we can tell you what it came out of.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
My Home Page
My contact info
Camaro Research Group
Old Oct 21st, 12, 10:47 PM
Garfields Maro Garfields Maro is online now
Garth
Yeah Carl, there's usually 2 seperate stamped codes on a transmission case; 1) a trans code and 2) a partial VIN. Sounds like you've got the trans code down. The "U" as mentioned above, is part of the partial VIN....the plant where the car was built.
http://camaros.org/drivetrain.shtml#trans
I bet you already knew that !?!....
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Oct 22nd, 12, 01:45 PM
DT DT is online now
Donny
Thanks for the replies guys. I dropped the trans off to be freshened up and will get the vin# when I get the trans back. Thx again.
Old Nov 12th, 12, 06:03 PM
DT DT is online now
Donny
Ed
Just received the trans back. Here is the vin# 28U158853
Old Nov 12th, 12, 06:10 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
1968 Pontiac - Firebird.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Nov 12th, 12, 06:32 PM
DT DT is online now
Donny
Thanks Big B !!!
Old Nov 12th, 12, 06:45 PM
twozs twozs is offline
mike
what says its a muncie from that # ? im just trying to learn here .
Old Nov 12th, 12, 07:07 PM
Ed
Nothing says it's a Muncie except what the original poster wrote.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
My Home Page
My contact info
Old Nov 12th, 12, 09:30 PM
Garth
Go back to post #4 about the 2 seperate codes; partial VIN and trans code........and click on the link to CRG.
