Rear leaf spring install question - Team Camaro Tech
Thread Tools Display Modes
Old Oct 30th, 12, 09:26 PM
attilio attilio is offline
Mike
Default Rear leaf spring install question
Is there a L & R rear leaf spring, or are they interchangeable?
Reason being is that I removed the front eye bushings and just put new ones in without keeping track of which spring came from the original location.
I have Global West L16 leaf springs and just installed there Del-A-Lum bushing and shackle kit. Now the rear end is shifted to the driverís side about a Ĺ inch from the passenger side. Now the drivers tire rubs on the fender lip. Seems like the rearend is not correctly centered now, but everything is correctly installed.
Old Oct 30th, 12, 11:54 PM
Garfields Maro Garfields Maro is online now
Garth
Default Re: Rear leaf spring install question
Although I'm not familar with those particular springs, I don't believe there's any difference, L or R. The bolt that goes through each leaf spring is properly located in the rearend/shock plate holes, right ?
You can check for square by measuring diagonally, assuming the subframe is square with the body. Might be better points to measure from, but it's pretty easy to put the end of the tape measure on the lower front ball joint grease fitting and measure back to the oppsosite side leaf spring alignment bolt at the bottom of the shock plate.
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Oct 31st, 12, 02:26 AM
ZLP955 ZLP955 is offline
Tim
Did you tighten the spring shackle bolts up to final torque settings with the full weight of the car on the springs?
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA.
Link to mark x22's excellent templates & diagrams:
http://s1218.photobucket.com/user/ZL...?sort=3&page=1
Old Oct 31st, 12, 08:42 AM
Mike
Everything is properly mounted and tightened.
Because these springs are 1 1/2 lowering springs it is really now noticeable. Before the tires were below the inner well, now they are tucked under by over an inch. The rear end may always have been offset to the driver’s side. Just seeing if anyone else has an issue like this?
Old Oct 31st, 12, 09:21 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Is it possible the new bushings are meant to install from a certain direction in the spring eyes?
Other than that, is it possible the spring pack locator pins in the axle spring perches are off centered?
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Oct 31st, 12, 09:50 AM
Mike
The Global West bushing kit can only be installed in one way. They are installed as the direction listed and are centered within the spring eyes.
Regarding the perches, I am going to measure then this afternoon. The rear end was from a 1972 Nova and is a 10 bolt, which is a direct replacement and fit for a 1969 Camaro. It has never been messed with, so I would assume that they are mounted correctly. The centering holes are correct also.
I will be measuring the fenders to see if anything is off there. The car may have been in a wreck and the fenders not properly set correctly. That is the only explanation I can think of??
Old Oct 31st, 12, 10:06 AM
Mike
Can someone please give me the correct measurement for the rear inner fender well to the outside fender lip?
Just want to see if there was some rear quarter panel work done, and if so, which side is correct.
Thanks.
Old Oct 31st, 12, 07:42 PM
67sc 67sc is offline
Kev
Off topic a bit but this makes me think we should take measurements before taking things apart so if things go wrong (like now) we have a point of reference.
Sorry the OP is having trouble and I have no help
Old Oct 31st, 12, 08:46 PM
Steiner Steiner is offline
Steiner
I've got the same springs (which are centered fine) and can check fenders tomorrow if I remember. When I put mine in I had to leave the bottom of the shackles practically undone to get enough wiggle in the leaf to get the perch on the locator pin correctly, and it took some work with some small pry bars. I used the standard bushing that came in the front of the GW leafs after reading on lateral-g and other places that using a solid or poly bushing in the front can cause binding during cornering. Used the Energy Suspension heavy duty shackle and bushing kit in the rear.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Nov 5th, 12, 10:44 PM
Mike
After looking around on different sites, I have found that others (mainly Nova guys) have reported the same issue. I guess most 60’s cars had issues with the rear axle not being perfectly centered between the rears of the cars fenders.
I have measured the distance from the inner wheel wells to the outside fender lip on both sides and they are within a 1/16 of an inch. So that not the problem. I did not notice this problem until I lowered the car with the lowering springs.
  #11
Old Nov 6th, 12, 02:52 AM
Garth
Loosen the shackle bolts (2/side) and front spring eyes, and bounce it around....Take it for a SPIRITED drive.
Maybe she'll settle down into the proper position.....
Disclaimer : Not too loose & SPIRITED....
  #12
Old Nov 6th, 12, 03:59 AM
Everett#2390's Avatar
<Jake-68's rule
I guess most 60ís cars had issues with the rear axle not being perfectly centered between the rears of the cars fenders.
An idiosyncrasy of these cars, normal.
Mine had one slick even with the opening, the other side the slick was inside the edge.
As a tip for later in life, you may want to remove the front hanger bolts, one at a time, and dope the threads with antiseize for easier removal next time.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Rear leaf spring install question
Location
Location
First Name
Human Verification
