92 Trans-Am WS6 Power Steering Box - Team Camaro Tech
Thread Tools Display Modes
Old Nov 4th, 12, 10:34 AM
USN1969SS USN1969SS is offline
Dave
Default 92 Trans-Am WS6 Power Steering Box
I found a 1992 Trans-Am WS6 being parted out, has 16 inch wheels. From the research I have done this looks like the same power steering box as the IROC, does anyone know for sure? I will go and look to see if the casting numbers are the same and if it still has the two letter stamp on it. Want to use it on my 1969 manual steering car.
Also, he is asking $75 with him pulling, is that a fair price? There is no engine in car so it should be a relatively simple pull. I know I can get a rebuilt Cardone for about double that but it basically would be like new where as not sure what your getting with used...
Thanks for any info/thoughts
Dave.
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
http://www.camaros.net/forums/pictur...pictureid=4730
Old Nov 4th, 12, 12:26 PM
TJS69 TJS69 is offline
Tom
Smile Re: 92 Trans-Am WS6 Power Steering Box
That box would be perfect for you. See if you can get the pump and hoses too. I'm not sure if the hoses are close enough in length or not, but you wouldn't need to use adapters then. I would trust that box more than a Cardone rebuild.
Rock Auto shows the pressure hose as being 33" long. They also show the Lares box for $59.00. So is used worth $75.00 ? I would offer hoses and pump and the box for $100
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Nov 16th, 12, 11:27 AM
sbauerz28 sbauerz28 is offline
steve
Default Re: 92 Trans-Am WS6 Power Steering Box
I would buy just the box and then get the 2 line adaptors and rag joint sold a a kit from Lee Manufacturing. The kit will run you just under $100 shipped. With that box and adaptor kit it will be a direct bolt on. This is an exellent upgrade. I did mine last spring.
1969 Camaro RS 496 BB Lunati roller cam Brodix heads D&D Performance T-56 Global West and Hotchis suspension
Old Nov 17th, 12, 01:49 PM
Tom
He is switching from manual steering to power steering, so he will need the pump and hoses anyway.
Old Nov 19th, 12, 02:15 PM
Dave
Turned out to be a bust...went and looked at the car and seemed like an aftermarket box (no GM markings), owner admitted he didn't know if it was a ws6 or not, no pump, yada, yada so I passed on the box.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: 92 Trans-Am WS6 Power Steering Box
Location
Location
First Name
Human Verification
