Troubleshooting Diagnosing problems done here.
Old Mar 28th, 99, 05:42 PM
TonyMonte TonyMonte is offline
Default
Hi, when I was changing the spark plugs on my newly acquired 69 Camaro (350, powerglide, base) I found out that the distributor is lose. I can swivel it around about 2 inches. Unfortunately, there is no markings that I have found yet that tell me where it is suppose to line up.
And now the car doesn't start. I have been doing alot of work on the car in the past two weeks and haven't started it since (Electrical, body, but nothing mechanical). So I'm not sure if its the distributor, probally is, or something else.
Also, the plate that is over the bottom of the dist does not seem right. it's Chrome and it doesn't seem to fit exactly right. I tightened it down a little but it did not stop the moving of the dist.
Any suggestions??
Tony Montemagni
1969 Camaro (base)
350/PG
Old Mar 30th, 99, 03:47 PM
Scooter Scooter is offline
Default
You need to get rid of that chrome hold down and get a good one in there that won't allow the distributor to move. I'd recommend a factory style available at any GM dealer. Then you need to set the timing to get it to start. Does it have HEI or the stock points distributor?
If points, to get it at least to start, set it up so the little window is parallel with the firewall. If HEI, set it up so the plug in portion is parallel with the firewall, then hook up the timing light and set timing to specs.
