Is this normal roller cam wear?? - Team Camaro Tech
Old Nov 6th, 12, 08:32 AM
dubs68camaro dubs68camaro is offline
Default Is this normal roller cam wear??
My 460 is getting ready to go under the 496 knife real soon. Just pulled the intake off and noticed the wear marks. I just thought I'd throw this out there to be safe. It's no dug in at all. I guess it stands to reason that the roller lifters would leave some kind of a mark on the lobes. Is this normal wear? Thanks!
Click image for larger version
Old Nov 6th, 12, 09:08 AM
SIDEWAYS SIDEWAYS is offline
Default Re: Is this normal roller cam wear??
Actually is perfectly normal. So long as you dont feel any deep ridges, those lines will clean-up nicely with Scotchbrite. Just be sure to wash the cam thoroughly afterwards - Scotchbrite is NASTY stuff to an engine!!!!!
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
Old Nov 6th, 12, 09:11 AM
Actually I think I paniced a little too soon. I walked back out into the shop and stuck my little pinky through the slot in the block. 95% of that mark wiped away! whew! lol
Scotchbrite is awesome. I love taking shiny aluminum parts and give them a brushed look with that stuff. I took a polished Hilborn scoop and gave it a killer old school look!
Old Nov 6th, 12, 10:36 AM
Fred Ficarra Fred Ficarra is offline
Fred
You stay away from my stuff!
Yep, no need to panic. I noticed mine was the same and called Lunati. Perfectly normal they said.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) GV with Coan 8" converter, GV-OD, 8 track still on console and best et 10.617, 126.45mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Nov 6th, 12, 11:05 AM
Looks like I need to be careful what I type!!! LOL
Old Nov 6th, 12, 01:17 PM
DOUG G DOUG G is offline
RedЯuM
Normal... But if you do regular checks as you should....rule of thumb is if you can feel it with your finger nail, you have an issue.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Nov 6th, 12, 02:40 PM
What's regular? This thing sees 100 miles a year.
Old Nov 6th, 12, 03:09 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Then you won't have anything to worry about imo.
Some of the very aggressive profiles that require extreme spring pressures would need to be checked often-not really for cam lobe wear but for lifters failing and springs losing their strength. Lose a lifter and you have some really big problems.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Nov 7th, 12, 04:01 AM
Busted Knuckles Busted Knuckles is offline
Keep an eye on it, you should be fine.
That looks like a cast core. There are a lot of 'em working fine, shouldn't have any issues wit low lift/spring pressure, but I wouldn't go nuts on either.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Old Nov 7th, 12, 02:05 PM
RedЯuM
this .......once a year at your rate
I
I
V
I had a rocker trunnion break and lucky for me the little roller needles didn't come out
68 Camaro~ LSx
RedЯum <-Pics
Old Nov 7th, 12, 02:43 PM
Kevs67RSSS's Avatar
Kevs67RSSS Kevs67RSSS is offline
Kevin
Normal
Old Nov 7th, 12, 02:50 PM
z28rich's Avatar
z28rich z28rich is offline
richard
do not scotchbrite and wash the cam just wip it down with some wd40 and thats it. never wash a cam unless its a steel billet looks like a typaical roller cam to me.good to go
1969 Garnet Red Z/28-RS with Black stripes
and Black Deluxe Int. I found my build sheet
2012 Shelby SVTPP GT500 race red with dash signed by Caroll Shelby
RIP Mr Shelby
Old Nov 8th, 12, 06:45 AM
One thing I have done is some serious research to make sure that my springs match my cam match my lifters. As you guys know, you can have springs that are correctly matched for your roller cam but rated too high for your lifters. Just another way of running into mechancal failure!
For those of you that might have seen my thread on the wear marks on the valve stem tips, crane said that is most definately the fact that the hardened part of the valve tip has been worn off. These heads did have a TON of regular use miles before I just bolted them on to my big block.
Old Nov 8th, 12, 10:43 AM
zdld17 zdld17 is offline
Don
I have to ask, Is this a billet roller? What kind of spring pressure are you running? I had issues with a cast roller .
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Nov 8th, 12, 06:26 PM
That one is a cast comp roller and is not being reused. I'll probably list it on eBay. I'm going with a Lunati this time around. Trying to decide between the 50249, 50250 and the 60212. Will be about 140 on the seat and 350ish open.....maybe a little more.
