Rs/ss 350 - Team Camaro Tech
Old Nov 6th, 12, 04:49 PM
1stGenJunkie's Avatar
1stGenJunkie 1stGenJunkie is offline
Team Member
Keith
Default Rs/ss 350
Well, I finished replacing just about all the sheet metal on my '67 project and sent it off to got some mud and paint slung on it. So on to the drivetrain. Still looking for the original motor, but in the mean time going to have some fun with a GM crate motor and thought I'd share some photos;
Even with correct motor mounts and steering components, factory pan hits frame
So changed pick-up tube and pan
and painted the block orange
didn't like the valve cover color so
painted them
Keith
'69 Camaro SS 350 4spd 1992-96
'68 Camaro 327 TH400 1996-97
<Fords> the dark years
'67 RS/SS 350 4 spd 2011 - restoration in progress http://www.camaros.net/forums/showthread.php?t=202282
Old Nov 6th, 12, 06:40 PM
Andrew69's Avatar
Andrew69 Andrew69 is offline
Andrew
Default
Lookin' good!
Skunk Works
302DZ, M22W Muncie, 12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159 (Formally known as X33D80)
Old Nov 6th, 12, 07:04 PM
Z282NV Z282NV is offline
Joe
Default Re: Rs/ss 350
Great job . Now that is the way GM should have painted those motors in the first place. IMO the only other thing I would change is the breather. Not sure why they make that thing so big?
Z282nv........."its gotta be red"
http://s10.photobucket.com/albums/a130/z282nv/
Old Nov 6th, 12, 07:09 PM
code 55 69 code 55 69 is offline
Tech Team
Bob
AWESOME..what a beautiful engine would like to see the whole car when done
Old Nov 7th, 12, 04:11 PM
jcfcamaro jcfcamaro is offline
jared
Your way to lucky!!!
Old Nov 7th, 12, 06:19 PM
triumph675 triumph675 is offline
Tech Team
Duane
SWEEEET Motor !!!!! I will have that motor in my Camaro someday...
Old Nov 8th, 12, 07:17 PM
Team Member
Keith
Not sure I dig the vent breather either, in fact I would rather have period correct valve covers too. Off to the dyno here to do the GM break in:
Did pull a 5800, just to see, pretty typical I guess, I'll take it anyway:-)
Mating it to a TREMEC, only issue was modifying the dust shield, needed larger radius to clear one piece seal design
Hell of a time with pulleys and brackets, but finally got her figured out
In the sub-frame...hey gurus is the HEI going to fit??
Keith
Old Nov 8th, 12, 07:31 PM
X-77 keith X-77 keith is online now
keith
I put an HEI in a 69 a long time ago. Not positive, but thought I had to make a slight dent in the firewall. Used a piece of wood and a hammer. Couldnt realy tell unles you knew about the cars. Engine looks awsome . I have a Z now , but a big block looks way cool under the hood.
Old Nov 9th, 12, 05:39 PM
Joe
Very nice torque curve...if you can call it a curve. Now that is what I want in my car, ditch the breather and have period correct valve covers.... what an awesome piece.
Old Nov 9th, 12, 08:04 PM
Eric Kammerer Eric Kammerer is offline
Most likely no on the big cap HEI fit. Will be close. Maybe the car to car variance will be in your favor, or maybe you can get enough forward position on the subframe mounting locations as long as you can still get the fender gaps you want. But most times big HEI won't fit without a bit of firewall mod. And even if it just fits, it's got to be able to rotate for timing, etc.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
