Hp overkill - Team Camaro Tech
Old Nov 7th, 12, 01:12 PM
kv67ssrs kv67ssrs is offline
Default Hp overkill
I am plotting a new engine for my 67. Right now I am kinda leaning towards a 650hp 496 BBC.
The car will not see track time and is primarily a weekend cruiser...and maybe an occasional friendly deserted blacktop pull... I try drive it as much as I can weather/schedule permitting.
I am just getting sick of knowing that all the kids driving new Camaros and Mustangs would eat my lunch. But, I am just wondering if I am going overboard..
Dont want a high-strung small block
Dont want to go LS
Im aware of the install/weight issues
Right now the car has:
Warmed up original 350
TKO600
12 bolt w/ 373 posi
Lots of suspension upgrades
Thoughts??
Thanks,
Kip
Old Nov 7th, 12, 01:47 PM
rojo rojo is offline
Robert
Default Re: Hp overkill
I'm planning on pretty much the same setup for my '67. Go for it.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old Nov 7th, 12, 02:10 PM
Tom P's Avatar
Tom P Tom P is offline
Tom
IMO 650 HP big block in not overkill for the occassional weekend cruiser -especially if setup properly
I built a 496 last year for my '69 - its very streetable and a blast to drive.
SFC's and Cal-Tracs at a minimumum to get the power to the pavement
67 Camaro - new build
69 Camaro - survivor
Second owner numbers matching 327 granny car with A/C
http://photobucket.com/tomp_69_survivor
69 Camaro RS/SS
Merlin III 496 w/Brodix RR Ovals
242/248 @ 0.050 .631/.626 hyd roller 631 HP / 618 TQ
http://photobucket.com/tomp_496_SS_Camaro
Old Nov 7th, 12, 02:24 PM
Cdminter55 Cdminter55 is offline
Tech Team
Doug
I have a 67 Camaro with a 496 600+ hp. J.W. Performance TH400 and stall converter. Also I have 4:11 gears with Cal-Tracs on the rear. Just had it painted and still working on the interior. I also hope I didn't go overboard for the street.
Old Nov 7th, 12, 03:35 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
650 HP with a stick will be a real challenge to hook up on the street. Impossible really, even if you use a sticky tire like Hoosier Quick Time Pros.
The 496 with that big arm is going to make some serious low end torque.....making it even harder to hook in not so good conditions.
I would consider a 427ish BBC with a 250 shot of nitrous....will be easier to hook up and then you can manage the nitrous and bring on the power when you can handle it. If you want to make it a sleeper just install the nitrous gear under the intake, the kids will never be the wiser.
Just an idea.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Nov 7th, 12, 03:47 PM
mark191 mark191 is offline
mark
There's no such thing as a girl too pretty or a car too fast! Go for it!
68 originally ss (straight six) 406,Afr210,Bullet solid roller,rpm airgap,QF750,th400,3.73 Eaton posi.11.3@118
Old Nov 7th, 12, 04:16 PM
I realize putting the power to the pavement is gonna be an issue... I figure a gear swap will be in order to help with that. I really dont think I will be trying to launch the car that much anyways... in the effort to avoid breaking things....
Looking for insane roll-on power...
As for NOS... I dont want to deal with extra fuel plumbing... which was one of the reasons I am avoiding the LS set-up..
Old Nov 7th, 12, 06:59 PM
Lonnie P's Avatar
Lonnie P Lonnie P is offline
Lonnie
If you can build a pump gas all motor setup, you will love it.
Fuel mileage may not be that great, but the power is always there.
You start playing w/ a 250 shot, then you potentially get into race fuel for safety & an expensive bottle fill every night you take the car out. Figure about 2# N2O ($10) per pass. I ran a small block Nova with a 175 shot & it cost me $50 every night I went out.
For my next build, I went with a ProCharger & spent the money one time instead of changing bottles constantly.
650 on the street is not too bad if you invest in the suspension & a good set of sticky tires. The 6 speed will make hooking it up more of a challenge. Try it on stock suspension/hard tires & there is a good chance you will need some paintwork from the times you cannot keep it in your lane.
Old Nov 8th, 12, 05:31 AM
67RS502 67RS502 is offline
have a friend with a Mark Jones 670hp 496 in a 71 Vette
car is pretty much stock xept motor.
mild gear and verter, mellow cam, rear streetable cruiser
runs 10.50s
Talk with Mark about one of his 496s
you need a fuel system and exhaust to support that kinda power.
at min. frame connectors and slapper bars with an good single adj. shock in the rear ... and tires. it will still be only good from a 50-60mph roll.
67 camaro 373s:
420 - 641hp HRcam 1.40, 9.90 @ 135
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
Old Nov 8th, 12, 06:02 AM
tonyvol tonyvol is offline
runs 10.50s
I agree with 67RS502...Give Mark Jones a call.
http://www.vortecproperformance.com/
Old Nov 8th, 12, 06:07 AM
Vega$69 Vega$69 is offline
Team Member
John
Personally I really like the ZZ502 or I'd go all out with a 572.
Not quite the power of a built 496 but extremely reliable and streetable.
I ran a ZZ502 in my 67 with a TKO 5 Speed and a 12 bolt with 3.55s. Was a great street machine and the OD tranny made it an absolute pleasure to drive.
I don't worry about the new Stangs and Camaros too much. Roll up next to one in a 1st gen and you don't have anything to prove.
I'm doing a built LS7 approx 635 hp with a 6 speed and I drive like an old lady (so says my son)
69 Pro Tour - LS7/T56 Building
C6ZO6 Vette Lemans Blue
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Nov 8th, 12, 07:19 AM
Mark Jones is who I was planning to go for my engine if I pull the trigger on this project. Great rep, reasonable $$ from what Ive seen...
A really dont worry too much about the newer cars... I know our rides have something they can never have.... but every once in a while.... ya just have to put the pups in their place...
Old Nov 8th, 12, 09:57 AM
copo9560 copo9560 is offline
Tom
Aftermarket has grown to the point where you can get a lot of BBC for the money. If you want to build your own but not chase down parts, look at this kit:
http://www.straubtechnologies.com/540-bbc-10-to-1-kit/
More power than GM's low compression 572 due to better heads. Low deck design makes a nice fit as well - add some orange paint and none of the new pony car guys will know what hit them. Straub is a big hit at Chevelle forum for custom cams.
Big power + manual trans usually ends up costing a bunch of money and things will break. T400 or even better 4L80 would be easier to drive and far quicker in 1/4 with the right converter.
Another option would be Procharger for your 350 - many options here as well and power is limited only by your wallet. This option would require significant fuel system upgrades.
'69 Coupe
Original 350 PG, Now 427 4 speed
Owned since 1977
Old Nov 8th, 12, 10:05 AM
satz28's Avatar
satz28 satz28 is online now
Rob
Default
Dont want to go LS
TKO600
12 bolt w/ 373 posi
Thoughts??
Thanks,
Kip
Don't forget the cost converting from a SB to a BB. What is a high strung SB?
Rob
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
Old Nov 8th, 12, 10:31 AM
I dont know what I consider high strung small block... huge cam, low vacuum maybe (something my wife cant drive)
After a doing some measuring, looks like I will have to scrap my current radiator/Mark VIII fan combo if I go big block...
... maybe I should just build another small block and be happy with it....
either way...I do appreciate the input....
