What brake calipers work with master power brake conversion - Team Camaro Tech
Old Nov 8th, 12, 12:25 AM
kc1969 kc1969 is offline
kevin
Default What brake calipers work with master power brake conversion
I was wondering if anyone knew what types (brands) of brake calipers work with a Master Power Disc brake conversion kit (front brakes)? I did the conversion sometime between 95 and 98, I believe, (rear conversion in 2004, yet to get it running) and with this current build I am looking to change the calipers. Hopefully I can still use the brackets (i believe they are from a mid size 90's chevy). My calipers were left in a garage that had a horrible roof leak and they rusted. Besides, they are probably very inferior. I hope not to replace the entire brake system again, (although wilwood and Baer are nice), but the engine does put out 500 hp.
kc
Old Nov 8th, 12, 01:09 AM
Steiner Steiner is offline
Steiner
Default Re: What brake calipers work with master power brake conversion
Hard to say. Depends on what they were using then. There are a few single piston calipers that have been used over the years in conversions I think. Best option may be to take one of yours and a bracket to the parts store and compare. Three applications that I know of that are different but can be used are:
'69-'74 Nova
'70-'81 Camaro
'78-88 Monte Carlo (metric)
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Nov 8th, 12, 01:19 AM
ZLP955 ZLP955 is offline
Tim
David Pozzi's site has a list of GM models whose brakes fit 1st Gens. Click on the link below and scroll down a way to the heading "DISC BRAKES THAT WILL FIT FIRST GEN CAMAROS"
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA; Now a work in progress.....
