'67 front suspension recommendations - Team Camaro Tech
Old Nov 8th, 12, 06:11 AM
Tom P's Avatar
Tom P Tom P is offline
Tom
Default '67 front suspension recommendations
I need some help on deciding on front suspension upgrades, there is almost too many choices
undergoing frame off, I have decided to keep the original front sub-frame and not cut on it. Getting it blasted and powdercoated. Since the car was original drum brakes, I'll upgrade spindles, control arms, springs/shocks, sway bar, body bushings, steering, front disc, etc.
Engine is all aluminum SBC with A/C.
I am considering-
  • Hotchkiss
  • BMR
  • Ride Tech (coil overs not air ride)
  • Chris Alston
  • CPP
  • Global West
100% street driven with little to no track time.
Front wheels either 17x8 or 18x8.
Overall drop between 2-3" and not planning on massaging any sheet metal
Any first hand experience and pictures would be great!
67 Camaro - new build
69 Camaro - survivor
Second owner numbers matching 327 granny car with A/C
http://photobucket.com/tomp_69_survivor
69 Camaro RS/SS
Merlin III 496 w/Brodix RR Ovals
242/248 @ 0.050 .631/.626 hyd roller 631 HP / 618 TQ
http://photobucket.com/tomp_496_SS_Camaro
Old Nov 8th, 12, 06:25 AM
BobKovacs BobKovacs is offline
Bob
Default Re: '67 front suspension recommendations
I just put the CPP Stage II kit on my 69. Can't provide any real-world handling comments yet, as I'm still a while from that point, but from the magazine reviews I've seen, the kit handles very well, and is much more affordable than the others. The fit and finish was excellent as well.
I went with the 4-wheel disc setup from Matt's Classic Bowties, which was about $300-400 less than going with the Stage III kit from CPP. At first glance they look similar, but the CPP kit doesn't include a power brake booster or new stainless lines.
Old Nov 8th, 12, 07:37 AM
Tom P's Avatar
Tom
Bob, good to hear fit and finish is excellent. what kind of drop (if any) does your kit provide? I see CPP has a new kit that includes C5 spindles.
69 Camaro RS/SS
Old Nov 8th, 12, 08:21 AM
Bob
It's got the adjustable coil-overs, so you can set it pretty much anywhere you want. I don't have anything to compare it to, as my subframe with the stock suspension wasn't on the car when I bought it. I also still have it sitting on jackstands, as the rear is being re-geared at the moment- should have it on the ground this weekend if all goes well. Of course, with no front end sheetmetal on the car, I won't really be able to tell how it's sitting yet anyway.
Old Nov 8th, 12, 08:43 AM
mahunt mahunt is offline
Michael
Hotchkiss 2" drop springs.
L&H Kustom Tall Non Drop Spindles.
JL8 front brakes (still fit a 15x7 space saver spare tire).
Global West lower A-arms.
ANY upper A-arm than doesn't include excessive caster which places the tire rearward and too close to the fenderwell (GW upper arms position the tire too far rearward).
1" sway bar to avoid any interference issues with a 1 1/8" hollow bar (which is more expensive too).
Regular or urethange body bushings.
Bilstein or Koni shocks.
Old Nov 8th, 12, 10:10 AM
Tom P's Avatar
Tom
thats an interesting point, never really thought about the reduced clearance at the fenderwell. Seems like many aftermarket uppers do have some additional caster built in.
69 Camaro RS/SS
Old Nov 8th, 12, 11:02 AM
67Rally's Avatar
67Rally 67Rally is offline
Brent
Hotchkis 2" springs, Bilstein shocks, Hotchkis sway bar, Fesler billet body mounts, SpeedTech UCA/LCA with tall upper ball joints, 6 piston Wilwood brakes, 18x8 Foose Legends with 245/45/18 Nitto's.
Great setup. No complaints. Pics in my signature.
Old Nov 8th, 12, 11:50 AM
67CAMARO496 67CAMARO496 is offline
matthew
i have speedtech performance road assault package which come with QA1 coilovers which are adjustable. raise and lower it how you want and also adjust how you want to ride
Old Nov 8th, 12, 11:59 AM
Tom P's Avatar
Tom
Thanks Brent, sits really nice with the 2" drop
69 Camaro RS/SS
Old Nov 8th, 12, 12:08 PM
Tom P's Avatar
Tom
theres a few aftermarket arms that are using the QA1 coilovers. have you had any issues running out of suspension travel and hitting the bump stops? I like the adjustable ride height
69 Camaro RS/SS
Old Nov 8th, 12, 12:19 PM
matthew
No problems so far. i love it too!!! lets you determine your own right height. also have them in the back as well. good luck with you build.
Old Nov 20th, 12, 02:06 PM
BMR Suspension BMR Suspension is offline
Rich
Tom,
I usually ask a few questions before I make any suggestions to determine the best possible bang for the buck.
I think many guys spend more than they need or will use. I pride myself in asking as many questions as possible before making a decision on what is best for the customers hard earned money.
First question is what do you have for goals for the car once it is done? Is it going to be a daily driver/weekend cruiser, weekend warrior/drag car, Pro-Touring/handling machine, etc.
Second question is do you need and/or plan to improve the braking & steering systems to compliment any suspension upgrades?
Third question is do you have a specific budget in mind?
Lastly, do you plan to do the work yourself?
Rich
BMR SUSPENSION, TAMPA FL
Our 67-69 suspension on Two Guys Garage:
http://youtu.be/n60dENFWPFY
813-986-9302 Phone
Rich@BMRSuspension.com
www.BMRSuspension.com
Old Nov 20th, 12, 04:28 PM
67Rally's Avatar
Brent
Originally Posted by BMR Suspension View Post
Tom,
The last two questions are legit. The first two were answered in the original post.
Old Nov 20th, 12, 04:29 PM
67Rally's Avatar
Brent
Thanks Tom. Very happy with my setup.
Old Jan 12th, 13, 07:03 PM
Tom P's Avatar
Tom
I ended up with the UCA and LCA, coil overs, truTurn package (including spindles) and front sway bar all from RideTech ala 48hr Camaro.
As soon as I get the subframe out from Pro Coat PowderCoat, I'll post up some install pics.
69 Camaro RS/SS
