hooker 2451 & trans mount - Team Camaro Tech
Old Nov 8th, 12, 06:12 PM
hardluckdog hardluckdog is offline
rich
Default hooker 2451 & trans mount
So has anyone had a problem with the header tube and the trans mount being in the way? Cut off the flange and about 1/4 of the three inch tube will hit the mount.Energy suspension mounts. Muncie M20.
Old Nov 8th, 12, 08:00 PM
TJS69 TJS69 is offline
Tom
Smile Re: hooker 2451 & trans mount
You mean the transmission crossmember ?
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Nov 8th, 12, 09:05 PM
Steiner Steiner is online now
Steiner
Default Re: hooker 2451 & trans mount
Can you snap a picture of one of the motor mounts and frame stands, and a pic of the trans mount or give the measurement of the trans mount height (the rubber or poly block between the trans crossmember and trans)?
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Nov 12th, 12, 04:54 PM
rich
yes
Old Nov 12th, 12, 05:15 PM
rich
Here is the motor mount. Trans polly is 1 7/8 inch tall.
Click image for larger version
Name:	2 mount.jpg
Old Nov 12th, 12, 06:37 PM
Tom
It appears that you have the wrong engine mounts. It looks like you have the "short and wide" (67-68) engine mounts with 1969 302/350 frame mounts. You need the "tall and narrow" 1969 engine mounts.
What year is your car ? What engine was the car born with ?
This should raise the engine and lower the transmission (and hopefully your header collectors).
Old Nov 12th, 12, 08:17 PM
Tom
Here are two pictures of the energy suspension engine mounts on 1969 302/350 frame mounts (stands).
The red mount is the incorrect "short and wide" engine mount.
The black mount is the correct "tall and narrow" engine mount.
Old Nov 13th, 12, 10:35 AM
Tom
