Rear Sway Bar - Bushing End Links Question - Team Camaro Tech
Thread Tools Display Modes
Old Nov 10th, 12, 12:10 PM
norcal_68 norcal_68 is offline
Mike
Default Rear Sway Bar - Bushing End Links Question
Hey guys,
I noticed one of my end links on my rear sway bar is missing. Trying to find a replacement but first one to find out if this was installed correctly as it came with the car.
The first pic is how it is currently installed, w/o a spacer. Is this correct?
The second pic is a brand new 3 1/2'' end link/bushing set that I have. Can I use this with the spacing or do I need to get a new set? Anyone know what length I need? I was hesitant to measure the current one as it may not be correct.
I don't know whether this is a stock or aftermarket bar.
Thanks in advance.
Click image for larger version
ID:	30789   Click image for larger version
Old Nov 10th, 12, 02:49 PM
scblucam's Avatar
scblucam scblucam is offline
Scott
Default Re: Rear Sway Bar - Bushing End Links Question
Should have a spacer to make the arms of the bar roughly pararlell with the ground. The poly bushings will make it stiffer than the rubber bushings. You can trim the soacer to fit your combo.
68 302 M20 - 85 IROC Z
The older I get the faster I was.
Old Nov 10th, 12, 02:57 PM
Fred Ficarra Fred Ficarra is offline
Fred
Originally Posted by norcal_68 View Post
Hey guys,
Thanks in advance.
First Gens didn't have stock rear bars.
The clamp/retainer on the sub frame looks to be an Addco product. The bolt heads are strange. Addco uses a U bolt that's fed from one hole, then inside the sub frame and out the next hole. What those bolts screw into is a .
Here's my Addco;
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
Old Nov 10th, 12, 05:26 PM
Mike
Weird! My subframe doesn't have that welded plate with the bolt holes. Does every 69 subframe have that plate ? And where is the top side accessible from? Both sides are the same.
Thanks for the help.
Here's my Addco;
Old Nov 10th, 12, 05:29 PM
Mike
I don't feel like taking out my back seat right now to look if there's a nut on top.
Old Nov 13th, 12, 04:11 PM
Fred
Sorry Mike, I left out about 43 years of history. The first Addco bar was installed by me in 1969. The U bolts were tearing up the sub-frame so I gas welded that plate to re-enforce it. Then about 5 years ago Addco sent me a new bar for free (in picture) and took the old one back for their museum.
They don't make them like this anymore;
http://ss427.net/
Old Nov 13th, 12, 07:17 PM
scblucam's Avatar
Scott
Read what Fres said. There is no access from the top required. It is a aquarish U bolr threaded through two drilled holes in the subframe.
Wow Fred, that original makes the poly bushings look squishy.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Rear Sway Bar - Bushing End Links Question
Location
Location
First Name
Human Verification
